Ocean's Thirteen error
DiehrWolf
Post by DiehrWolf » Mon Aug 29, 2011 5:59 am
Movie: Ocean's Thirteen
Version: 1.6.1.2 - 1.6.1.4 (Windows 7 x64)
Region(s): 1
Video Standard: NTSC
DVD Name: OCEANS_THIRTEEN
Upon converting the movie to MKV, the program crashes and continuously writes a repetitive report (attached) which I stopped when it hit 15MB.
Debug log started at Mon Aug 29 01:03:59 2011 , written by MakeMKV v1.6.14 win(x64-release)
001005:0000 MakeMKV v1.6.14 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Diehr/MakeMKV_log.txt
003006:0000 Opening files on harddrive at E:/TV Shows/Ocean's -03- Thirteen/VIDEO_TS/
003028:0000 Title #0 was added (34 cell(s), 2:01:44)
005014:0000 Saving 1 titles into directory E:/DVD's/Ocean's -03- Thirteen
001003:0020 DEBUG: Code 1855 at WtF#"'***TGp@"|krRB"4:213133250
001003:0020 DEBUG: Code 2025 at WtF#"'***TGp@"|krRB"4:213133250
001003:0020
(continues)
If you need anything else, let me know!
Thanks a bunch for all your hard work, you bunch of bada**'s you!
VTS_Files.rar
VTS Files (1-3)
(29.31 KiB) Downloaded 1109 times
MakeMKV_log.rar
MakeMKV Log
(427.81 KiB) Downloaded 1058 times
VIDEO_TS.rar
Video_TS File
(598 Bytes) Downloaded 1080 times
DiehrWolf
Re: Ocean's Thirteen error
Post by DiehrWolf » Sat Sep 24, 2011 4:26 am
*UPDATED*
Version: 1.6.1.5 (Windows 7 x64)
Region(s): 1
Debug log attached.
MakeMKV_log.txt
*TESTDUMP* log as of 09-23-2011 w/v1.6.1.5
(799.98 KiB) Downloaded 1078 times
Post by mike admin » Sun Sep 25, 2011 10:45 am
This should have been fixed in 1.6.15 . What happens if you DISABLE debug log - will it eventually work?
DiehrWolf
Post by DiehrWolf » Sun Sep 25, 2011 7:35 pm
mike admin wrote:This should have been fixed in 1.6.15 . What happens if you DISABLE debug log - will it eventually work?
It gets to about 75% then jumps to finish about 8-9seconds after the error shows up. It does finish the file, and it is playable, but there is no video for the remaining 25% of the video.
paulster
Post by paulster » Sun Oct 02, 2011 12:56 am
Mine freezes near the end too after running the original DVD through 1.6.15.
DiehrWolf
Post by DiehrWolf » Sun Oct 02, 2011 1:00 am
paulster wrote:Mine freezes near the end too after running the original DVD through 1.6.15.
My video freezes in the hotel room scene with the 'cougar'. Is yours in the same area too?
paulster
Post by paulster » Sun Oct 02, 2011 1:06 am
Beginning of Chapter 23 - "The Gilroy"? That's where mine freezes.
I've just checked my DVD ISO rip and that plays fine so it's the MKV version only, whether ripped from the ISO or direct from the disc itself.
DiehrWolf
Post by DiehrWolf » Sun Oct 02, 2011 1:19 am
paulster wrote:Beginning of Chapter 23 - "The Gilroy"? That's where mine freezes.
Same here, right about a minute in. Very odd.
paulster
Post by paulster » Sun Oct 02, 2011 1:22 am
Yep, that's the same spot.
DiehrWolf
Post by DiehrWolf » Mon Oct 10, 2011 8:37 am
lawyevara wrote:So then can it be the problem with DVD in this case?
I don't believe that's the case, since the playback before conversion, plays just fine. Also, I can use Handbrake to convert it to MKV, but I have a love hate relationship with H.264 that handbrake uses, and I'd much rather use the original MPEG2 from the dvd. But I digress.
Speaking of which, Paulster, if you have your DVD case around for 'Ocean's Thirteen', could you please PM the UPC on the DVD Box to "mike admin". I have mine locked up in storage (along with my other 900+ DVD cases) and I haven't had the time (or willpower) to dig for it. If they'd just stamp it on the disc somewhere I could just get it out of my DVD binder =/.
paulster
Post by paulster » Mon Oct 10, 2011 3:30 pm
DiehrWolf wrote:Speaking of which, Paulster, if you have your DVD case around for 'Ocean's Thirteen', could you please PM the UPC on the DVD Box to "mike admin".
Done.
DiehrWolf
Post by DiehrWolf » Mon Oct 10, 2011 5:52 pm
Thanks a ton. You saved me from an expedition.
DiehrWolf
Post by DiehrWolf » Sat Oct 29, 2011 5:18 am
SUCCESS!! MakeMKV strikes again! Converted perfectly and I'm a happy camper.
paulster
Post by paulster » Sat Oct 29, 2011 4:58 pm
Yep, my copy of Ocean's Thirteen went through perfectly this time!
Thanks Mike.
BigDaddyD
Post by BigDaddyD » Sun Aug 18, 2019 2:34 am
Sorry for bringing this thread back from the dead - but what was the fix for this?
I'm having the exact same problem with my copy of Ocean's 13.
