kazuma
Post by kazuma »
reset_9999 what is not working right with your gigabit-port of the ugoos? is that on alle devices of am6b? or just some?
don't worry about it if you don't have a 10gbps network/hardware.
I have two Ugoos devices and they both behave the same.
kazuma
Post by kazuma »
RESET_9999 wrote:
Sat Jun 08, 2024 5:34 pm
what? do you have a 10gbit internet line in your house :D
I have a 3gbps plan but my internet speed is irrelevant. A 10gbps local network can be very useful without fast internet.
chronomac
Post by chronomac »
Anyone know if Dead Reckoning has raised brightness levels like the rest of the M:I series? I didn't see it in the DV Google Sheet but wanted to double-check.
I post only the ones that expand brightness in that section of the spreadsheet. Look at the other tabs below, there's one called ''screenshot comparisons'' where I do the ones that don't expand brightness.
Epedemic
Post by Epedemic »
Another issue with 3-2 for me, this time on a HDR10 file. Happens when madvr measurement is supposed to take place:
https://imgur.com/a/7wkivLx
I redownloaded the tools folder, tried the latest beta, and also older versions to no avail. Any suggestions to what i have messed up this time? :D
*edit*: Never mind, rolling LAV Filters back to stable (0.79.2) did the trick.
sofakng
Post by sofakng »
Sorry if this is off-topic but what is the best playback using Windows on a PC ultrawide monitor?
I’ve purchased the AM6B+ for my OLED TVs but I would also like to play my UHD remuxes on my ultrawide monitor.
My ultrawide does support HDR (not Dolby vision) but it’s not great.
Mrmorrison
Post by Mrmorrison »
Good morning guys, what addons do you use on Kodi for Plex?
Thank you
deadchip12
Post by deadchip12 »
If I own the Sony X700, is it worth it to buy the Ugoos AM6 Plus? Will there be improvements in picture quality?
sofakng wrote:
Wed Jun 12, 2024 5:34 pm
MPC-HC (or BE) + madvr(best upscaler) or Windows Energy player (support DV decoding in HDR10 or SDR)
https://apps.microsoft.com/detail/9p9zh ... n-us&gl=CA
https://www.videohelp.com/software/madVR
https://www.videohelp.com/software/MPC-BE
deadchip12 wrote:
Fri Jun 14, 2024 9:15 am
If your TV is CMV4.0, yes. if not, it's still more practical to watch DV movie in mkv container via the network.
Mrmorrison wrote:
Thu Jun 13, 2024 7:00 am
I use the plex ''composite'' addon with Arctic Zephyr skin. You can configure it to work exactly like plex.
deadchip12
RESET_9999 wrote:
Fri Jun 14, 2024 11:08 am
Thanks for the reply. My tv is Sony A95L. How can I find out whether it is CMV4.0 or 2.9?
Also, do you have a video that shows the difference in image quality between CMV4.0 on the Ugoos vs CMV2.9 on the X700?
deadchip12 wrote:
Fri Jun 14, 2024 11:27 am
Try this in your TV internal player:
1000nits rpu: https://drive.google.com/file/d/172cFIm ... drive_link
4000nits rpu: https://drive.google.com/file/d/1V4glXo ... sp=sharing
if you see brightness adjustments, it supports cmv4.0. If it was made after 2019, it most likely support it.
more test files: https://drive.google.com/drive/u/1/fold ... V0E3VVkhiC
The black clipping pattern is crushed in cmv2.9 but not in cmv4.0:
cmv4.0: https://drive.google.com/file/d/1Ev16KY ... drive_link
cmv2.9: https://drive.google.com/file/d/1cINlFZ ... drive_link
deadchip12
RESET_9999 wrote:
Fri Jun 14, 2024 12:10 pm
Since i dont have super uber fast internet, is there any issue with playback via usb?
I read your spreadsheet and watched the video where you mentioned most bluray releases are cmv2.9. Since i dont plan to do the "transfer cmv4.0 bloc to a cmv2.9 FEL rpu" (seems quite complicated and time consuming), is getting the ugoos just for cmv4.0 still worth it?
deadchip12 wrote:
Fri Jun 14, 2024 12:58 pm
Yes, its a lot better than any other device...
- mkv container is more practical, you can watch makemkv p7 mkvrip without any remuxing/processing to TS.
- Cropped content play properly (no grey black bars)
- gigabit ethernet port
- wifi 6
- no dual track dual layer green screen bug
- no ff/rw bug with long movies
- srt subtitles work
- chapter works
- ISO works
- movie poster, description, rating, tracks info
- Bluetooth remote (x700 remote is garbage). you can also use your TV remote to control it
- playback history/ resuming
Your internet speed and your internal network speed are two different things. In other words, you can stream your movie without an internet connection but USB playback is fine too.
