Good morning everyone.
I found a dump_FW_xxxxxx.tgz file in the ~/.makemkv directory and, not knowing what it was, I deleted it. Then later by starting MakeMKV I saw that it is the program that creates this file and invites me to send it to support@makemkv.com.
What is this file? And why do I have to send it? Thank you.
File dump_FW
Re: File dump_FW
its info about your fw that the developer may be able to use to expand libredrive.
what drive do you have?
better to just show us your makemkv drive info just copy paste it ill tell you if its worth sending in.
Re: File dump_FW
First of all thank you. I have a Pioneer BD-R 212v. Here's the info from MakeMKV:Billycar11 wrote: Fri Jun 14, 2024 9:12 am its info about your fw that the developer may be able to use to expand libredrive.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212v
Revision: 1.02
Serial number: (cut)
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Libredrive information
Firmware version: ID06
Re: File dump_FW
Nah that not really worth sending in but that drive can do UHD if you want the flasher for it email me.
Re: File dump_FW
Ok. For now I'm not interested in UHD, if one day I change my mind (I don't think so) I will contact you. Thank you.Billycar11 wrote: Fri Jun 14, 2024 9:02 pm Nah that not really worth sending in but that drive can do UHD if you want the flasher for it email me.
