Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
jkboyo
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
#31 Post by jkboyo » Thu Jun 13, 2024 7:39 pm
Coopervid wrote: Sun Jun 09, 2024 7:32 pm
jkboyo wrote: Sun Jun 09, 2024 1:18 pm
Coopervid wrote: Sat Jun 08, 2024 8:51 pm
Country of residence?
USA
Check you PM.
I got the 5.25 internal one.
#32 Post by Coopervid » Fri Jun 14, 2024 9:12 am
jkboyo wrote: Thu Jun 13, 2024 7:39 pm
USA
Check you PM.
Check your PM.
dm23456
#33 Post by dm23456 » Fri Jun 14, 2024 9:07 pm
Godzilla x Kong: The New Empire
"No disc inserted" ??
Is there a way to update the firmware?
OS device name: A:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: SKDL009566UC
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.02
#34 Post by Billycar11 » Fri Jun 14, 2024 11:24 pm
dm23456 wrote: Fri Jun 14, 2024 9:07 pm Godzilla x Kong: The New Empire
OS device name: A:
Revision: 1.02
Already responded to your email
smoove_op
#35 Post by smoove_op » Sat Jun 22, 2024 5:11 am
Hi all, I *also* have a BDR-XD07 that I'd like to flash for UHD; looks like it's old enough that it can still be flashed, luckily.
Info below:
Revision: 1.01
Serial number: [redacted]
Firmware date: 2018-12-03
Highest AACS version: 21
Drive platform: Pioneer RS8D30
Firmware version: ID36
#36 Post by Billycar11 » Sat Jun 22, 2024 2:54 pm
smoove_op wrote: Sat Jun 22, 2024 5:11 am Hi all, I *also* have a BDR-XD07 that I'd like to flash for UHD; looks like it's old enough that it can still be flashed, luckily.
Info below:
Revision: 1.01
Email me that info
see below
smoove_op
#37 Post by smoove_op » Sun Jun 23, 2024 9:57 pm
Billycar11 wrote: Sat Jun 22, 2024 2:54 pm Email me that info
see below
Everything worked perfectly, thanks a ton for the help!
ftabgm
#38 Post by ftabgm » Sat Jul 27, 2024 9:25 pm
Howdy Coopervid, I have this drive with the following:
Revision: 1.02
Is there a solution for this drive to function with UHD you are aware of?
#39 Post by Coopervid » Sun Jul 28, 2024 10:31 am
ftabgm wrote: Sat Jul 27, 2024 9:25 pm Howdy Coopervid, I have this drive with the following:
Revision: 1.02
Read your PM.
Gradius1980
#40 Post by Gradius1980 » Mon Jul 29, 2024 12:36 pm
Hey Coopervid
Would it be possible for you to send me the files to enable this on my XD07 as well please, details are:
OS device name: V:
Revision: 1.03
Firmware date: 2020-08-20
Firmware version: 1.03
#41 Post by Coopervid » Mon Jul 29, 2024 6:50 pm
Gradius1980 wrote: Mon Jul 29, 2024 12:36 pm Hey Coopervid
OS device name: V:
Revision: 1.03
PM sent.
Gradius1980
#42 Post by Gradius1980 » Tue Jul 30, 2024 11:30 am
Worked perfectly, thanks for your help.
JCE3000GT
#43 Post by JCE3000GT » Sun Oct 06, 2024 5:22 pm
Hello all. Looks like I found the right forum for my issue. Looking to start a home server and need to rip all my discs but naturally I cannot read 4K/UHD discs. Started with Dune and all it does is spin up and down in a cycle. Can this drive be converted?
Revision: 1.02
Highest AACS version: 20
#44 Post by Coopervid » Sun Oct 06, 2024 8:23 pm
JCE3000GT wrote: Sun Oct 06, 2024 5:22 pm Hello all. Looks like I found the right forum for my issue. Looking to start a home server and need to rip all my discs but naturally I cannot read 4K/UHD discs. Started with Dune and all it does is spin up and down in a cycle. Can this drive be converted?
Revision: 1.02
PM sent. It will expire in one week.
JCE3000GT
#45 Post by JCE3000GT » Sun Oct 06, 2024 9:37 pm
Coopervid wrote: Sun Oct 06, 2024 8:23 pm
Revision: 1.02
Thank you! I'll give it a go shortly.
