I got the 5.25 internal one.
Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Godzilla x Kong: The New Empire
"No disc inserted" ??
Is there a way to update the firmware?
OS device name: A:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: SKDL009566UC
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.02
OS device name: A:
Revision: 1.02
Already responded to your emaildm23456 wrote: Fri Jun 14, 2024 9:07 pm Godzilla x Kong: The New Empire
OS device name: A:
Revision: 1.02
Hi all, I *also* have a BDR-XD07 that I'd like to flash for UHD; looks like it's old enough that it can still be flashed, luckily.
Info below:
Revision: 1.01
Serial number: [redacted]
Firmware date: 2018-12-03
Highest AACS version: 21
Drive platform: Pioneer RS8D30
Firmware version: ID36
Info below:
Revision: 1.01
Email me that infosmoove_op wrote: Sat Jun 22, 2024 5:11 am Hi all, I *also* have a BDR-XD07 that I'd like to flash for UHD; looks like it's old enough that it can still be flashed, luckily.
Info below:
Revision: 1.01
see below
Everything worked perfectly, thanks a ton for the help!
Howdy Coopervid, I have this drive with the following:
Revision: 1.02
Is there a solution for this drive to function with UHD you are aware of?
Revision: 1.02
Read your PM.ftabgm wrote: Sat Jul 27, 2024 9:25 pm Howdy Coopervid, I have this drive with the following:
Revision: 1.02
Gradius1980
Hey Coopervid
Would it be possible for you to send me the files to enable this on my XD07 as well please, details are:
OS device name: V:
Revision: 1.03
Firmware date: 2020-08-20
Firmware version: 1.03
OS device name: V:
Revision: 1.03
PM sent.Gradius1980 wrote: Mon Jul 29, 2024 12:36 pm Hey Coopervid
OS device name: V:
Revision: 1.03
Gradius1980
Worked perfectly, thanks for your help.
Hello all. Looks like I found the right forum for my issue. Looking to start a home server and need to rip all my discs but naturally I cannot read 4K/UHD discs. Started with Dune and all it does is spin up and down in a cycle. Can this drive be converted?
Revision: 1.02
Highest AACS version: 20
Revision: 1.02
PM sent. It will expire in one week.JCE3000GT wrote: Sun Oct 06, 2024 5:22 pm Hello all. Looks like I found the right forum for my issue. Looking to start a home server and need to rip all my discs but naturally I cannot read 4K/UHD discs. Started with Dune and all it does is spin up and down in a cycle. Can this drive be converted?
Revision: 1.02
Thank you! I'll give it a go shortly.Coopervid wrote: Sun Oct 06, 2024 8:23 pmPM sent. It will expire in one week.JCE3000GT wrote: Sun Oct 06, 2024 5:22 pm Hello all. Looks like I found the right forum for my issue. Looking to start a home server and need to rip all my discs but naturally I cannot read 4K/UHD discs. Started with Dune and all it does is spin up and down in a cycle. Can this drive be converted?
Revision: 1.02
