TERMINAL won't play
Shnick
TERMINAL won't play
Post by Shnick » Thu Jun 13, 2024 4:00 pm
I was successful in ripping the Bluray to an mkv, but VLC and/or my Optical Drive (BU40N) wont play the disc. It's a region A disk, and i thought firmware 1.04 was supposed to unlock the regions. Which do I address first, the drive or VLC?
OS device name: E:
Product: BD-RE BU40N
Revision: 1.04
Serial number: [redacted]
Firmware date: 2120-05-06 11:42
Highest AACS version: 64
Firmware version: 1.04
Disc Information
Label: TERMINAL
Timestamp: 2018-05-09 14:02:08
Protection: AACS v64
Data capacity: 20.4 Gb
Disc type: BD-ROM
Number of layers: 1
Re: TERMINAL won't play
Post by dcoke22 » Fri Jun 14, 2024 7:40 pm
If you successfully made a .mkv from the blu-ray, I'm not sure why you're trying to play the disc?
I have no idea why VLC won't play the disc if you've got VLC checked on the integration tab in MakeMKV's preferences. It isn't a feature I ever take advantage of.
The Ultimate UHD Drives Flashing Guide recommends, however, that LG BU40N drives be flashed to 1.03 firmware. I have no idea if that matters for disc playback.
BU40N on any Firmware directly to > BU40N 1.03MK
Shnick
Post by Shnick » Wed Jun 19, 2024 1:30 am
Thanks, i'll give it a try.
