DEBUG: Code 284 at 'gG7(;6S8+IE0DW;/v:29398438
DEBUG: Code 0 at 'gG7(;6S8+IE0DW;/v:29403176
DEBUG: Code 0 at 'gG7(;6S8+IE0DW;/v:29403866
Title #0 (2:07:38) was skipped due to navigation error
Title #1 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Any other dump or crash log I should post?
Failed to open disc (Pixote)
setarip_old
Re: Failed to open disc (Pixote)
Hi!
Try cleaning the disc...Title #0 (2:07:38) was skipped due to navigation error
- Contact:
It's likely a bug in MakeMKV. Please submit IFO files per http://www.makemkv.com/faq/item/8/catid/6 .
phpisGOOD
Done. Hopefully this helps.
