Pirates of the Caribbean 2 blu-ray error
blujay
Post by blujay »
Was not able to rip blu-ray POTC2.
I first tried ripping the main title. It goes for a while... and then fails.
Then I tried backup. It goes for a while... and then fails.
Here is the log from my run...
MakeMKV v1.6.14 darwin(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-ROM HL-DT-ST DVDRWBD CT30N A101" opened in OS access mode.
File 00001.mpls was added as title #0
File 00002.mpls was added as title #1
File 00012.mpls was added as title #2
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #3
Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #4
File 00015.m2ts was added as title #5
File 00016.m2ts was added as title #6
File 00017.m2ts was added as title #7
Title #00018.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00023.m2ts was added as title #8
Title #00024.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00025.m2ts was added as title #9
Title #00026.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/external/makemkv
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6453725184'
Failed to save title 0 to file /Volumes/external/makemkv/title00.mkv
0 titles saved, 1 failed
Backing up disc into folder "/Volumes/external/makemkv/backup"
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6443372544'
Backup failed
.eol
reebok
Re: Pirates of the Caribbean 2 blu-ray error
Post by reebok »
I never got that error, but I had issues with all 3 pirates blurays. the last one I ended up just using a different program. I will be interested to see how the 4th one goes when I get it.
setarip_old
Post by setarip_old »
@blujay
Hi!
Try it ;>}
blujay
Post by blujay »
I noticed that in the log too (thanks), and installed the DASPI module.
Retried, and neither title rip, nor backup succeeds. Result. Failed. :(
Added debug to log.
First code section is output from makemkv window.
Second code section is contents of MakeMKV_log.txt
So, just not going to be able to rip this one, eh?
Debug logging enabled, log will be saved as /MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "BD-ROM HL-DT-ST DVDRWBD CT30N A101" opened in DASPI v1.3 mode.
Backing up disc into folder "/Movies/backup/PIRATES2"
Evaluation version, 24 day(s) out of 30 remaining
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6440484864'
DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:121267868
DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:213142542
Backup failed
Saving 1 titles into directory /Movies/PIRATES2
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6451494912'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6451531776'
DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394298
DEBUG: Code 0 at >Y%Q"#4rYx6\gYa>K4$8:121261681
DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394183
DEBUG: Code 3150162 at bt0(3+ZwGR.7zBTww2?#:29393309
DEBUG: Code 0 at [>a{Yff]psdpCqBw_s<H[:213134377
Failed to save title 0 to file /Movies/PIRATES2/title00.mkv
Contents of MakeMKV_log.txt
Debug log started at Sat Aug 27 15:15:15 2011 , written by MakeMKV v1.6.14 darwin(x86-release)
001005:0000 MakeMKV v1.6.14 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM HL-DT-ST DVDRWBD CT30N A101" opened in DASPI v1.3 mode.
005072:0000 Backing up disc into folder "/Movies/backup/PIRATES2"
005050:0000 Evaluation version, 24 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkECAEEAQIBDQAAAAAgAAAAAAAAAAA=
DCE=BpjgQ1QWGxpV3KeXpxGwKpi2j25460IjgQFJfJdCnomNs64gYsGlBri8mbOrCtKMCBg/TQ7CoFkahe5B67E9yR0FrN3JqlIxD+HPOGe0IGQKydnplilxOR5LW/NfbBmirxGYRj2UMBCPPjYk+MaM04RtgGBdonvMtg==
001003:0020 DEBUG: Code 1073741829 at Y9?7SI/E=]R=7,3d:29393953
001003:0020 DEBUG: Code 2 at ~n^PnlTYxtG(%Z(6:121268719
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6440484864'
001003:0020 DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:121267868
001003:0020 DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:213142542
005069:0080 Backup failed
005080:0204 Backup failed.
DCE=N3rWbgCjv0RAHVULBL6Dd41y5Ems6EVc0SiGN7FkIBHw6jREq3tqKFaQUCeMlxNpa40QrqlfK+zPcWutJ+uif2Tse+tBE6nlxN+E9T6KHYMrzRvv7ZGmC8dyflr4isSlDN3fa4t8XBc3K5fPItiI93qxMwpcdxvuVA==
DISCID=F79EB16374BE025A00937A0C332DB8C83CDAB54F
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003307:0000 File 00012.mpls was added as title #2
003025:0000 Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #3
003025:0000 Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00014.m2ts was added as title #4
003307:0000 File 00015.m2ts was added as title #5
003307:0000 File 00016.m2ts was added as title #6
003307:0000 File 00017.m2ts was added as title #7
003025:0000 Title #00018.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00023.m2ts was added as title #8
003025:0000 Title #00024.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00025.m2ts was added as title #9
003025:0000 Title #00026.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Movies/PIRATES2
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6451494912'
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6451531776'
001003:0020 DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394298
001003:0020 DEBUG: Code 0 at >Y%Q"#4rYx6\gYa>K4$8:121261681
001003:0020 DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394183
001003:0020 DEBUG: Code 3150162 at bt0(3+ZwGR.7zBTww2?#:29393309
001003:0020 DEBUG: Code 0 at [>a{Yff]psdpCqBw_s<H[:213134377
005003:0000 Failed to save title 0 to file /Movies/PIRATES2/title00.mkv
005004:0080 0 titles saved, 1 failed
.eol
setarip_old
I believe this is indicative of a physically damaged or dirty disc...
