ArArdin wrote:
Fri Jun 07, 2024 1:51 pm
Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?
1- mux a DT-DL MP4 in mkvtoolnix
2- mux raw hevc layers in mkvtoolnix but this produces a dvhe.07.03 file instead of dvhe.07.06
General
Complete name                            : D:\FEL TEST DT DL P7 CMV4.0 4000nits V3.mkv
File size                                : 25.3 MiB
Duration                                 : 1 min 0 s
Overall bit rate                         : 3 527 kb/s
Frame rate                               : 23.976 FPS
Writing application                      : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 3 165 kb/s
Bits/(Pixel*Frame)                       : 0.016
Stream size                              : 22.7 MiB (90%)
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 293 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.006
Stream size                              : 2.10 MiB (8%)
Complete name                            : D:\00000.track_4113.mkv
File size                                : 381 MiB
Overall bit rate                         : 52.8 Mb/s
Video #1
Bit rate                                 : 52.7 Mb/s
Bits/(Pixel*Frame)                       : 0.265
Stream size                              : 381 MiB (100%)
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 694 cd/m2
Maximum Frame-Average Light Level        : 61 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 69.3 kb/s
Bits/(Pixel*Frame)                       : 0.001
Stream size                              : 512 KiB (0%)
ArArdin
Post by ArArdin »
RESET_9999 wrote:
Fri Jun 07, 2024 2:07 pm
Thanks, RESET. And sorry to get back on this but I had a go on both and not sure what to think here.
When importing separate BL and EL+RPU in MTX, MediaInfo indeed shows "Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03" on resulting mkv.
The above elementary tracks I extracted from a dtdl mp4, which I too - directly - imported in MTX. Weird thing here is that MediaInfo doesn't mention Dolby Vision anywhere on the mkv result.
Don't know what's happening here; do I have to set something manually in MTX GUI on DTDL mp4 import?
[EDIT] My apologies, never mind. I had a flawed mp4 source that was created with ffmpeg.
Did it with a dtdl mp4 created with mp4muxer, things are now peachy
kazuma
Post by kazuma »
reset_9999 what is not working right with your gigabit-port of the ugoos? is that on alle devices of am6b? or just some?
don't worry about it if you don't have a 10gbps network/hardware.
I have two Ugoos devices and they both behave the same.
kazuma
Post by kazuma »
RESET_9999 wrote:
Sat Jun 08, 2024 5:34 pm
what? do you have a 10gbit internet line in your house :D
I have a 3gbps plan but my internet speed is irrelevant. A 10gbps local network can be very useful without fast internet.
chronomac
Post by chronomac »
Anyone know if Dead Reckoning has raised brightness levels like the rest of the M:I series? I didn't see it in the DV Google Sheet but wanted to double-check.
I post only the ones that expand brightness in that section of the spreadsheet. Look at the other tabs below, there's one called ''screenshot comparisons'' where I do the ones that don't expand brightness.
Epedemic
Post by Epedemic »
Another issue with 3-2 for me, this time on a HDR10 file. Happens when madvr measurement is supposed to take place:
https://imgur.com/a/7wkivLx
I redownloaded the tools folder, tried the latest beta, and also older versions to no avail. Any suggestions to what i have messed up this time? :D
*edit*: Never mind, rolling LAV Filters back to stable (0.79.2) did the trick.
sofakng
Post by sofakng »
Sorry if this is off-topic but what is the best playback using Windows on a PC ultrawide monitor?
I’ve purchased the AM6B+ for my OLED TVs but I would also like to play my UHD remuxes on my ultrawide monitor.
My ultrawide does support HDR (not Dolby vision) but it’s not great.
Mrmorrison
Post by Mrmorrison »
Good morning guys, what addons do you use on Kodi for Plex?
Thank you
deadchip12
Post by deadchip12 »
If I own the Sony X700, is it worth it to buy the Ugoos AM6 Plus? Will there be improvements in picture quality?
sofakng wrote:
Wed Jun 12, 2024 5:34 pm
MPC-HC (or BE) + madvr(best upscaler) or Windows Energy player (support DV decoding in HDR10 or SDR)
https://apps.microsoft.com/detail/9p9zh ... n-us&gl=CA
https://www.videohelp.com/software/madVR
https://www.videohelp.com/software/MPC-BE
deadchip12 wrote:
Fri Jun 14, 2024 9:15 am
If your TV is CMV4.0, yes. if not, it's still more practical to watch DV movie in mkv container via the network.
Mrmorrison wrote:
Thu Jun 13, 2024 7:00 am
I use the plex ''composite'' addon with Arctic Zephyr skin. You can configure it to work exactly like plex.
deadchip12
RESET_9999 wrote:
Fri Jun 14, 2024 11:08 am
Thanks for the reply. My tv is Sony A95L. How can I find out whether it is CMV4.0 or 2.9?
Also, do you have a video that shows the difference in image quality between CMV4.0 on the Ugoos vs CMV2.9 on the X700?
deadchip12 wrote:
Fri Jun 14, 2024 11:27 am
Try this in your TV internal player:
1000nits rpu: https://drive.google.com/file/d/172cFIm ... drive_link
4000nits rpu: https://drive.google.com/file/d/1V4glXo ... sp=sharing
if you see brightness adjustments, it supports cmv4.0. If it was made after 2019, it most likely support it.
more test files: https://drive.google.com/drive/u/1/fold ... V0E3VVkhiC
The black clipping pattern is crushed in cmv2.9 but not in cmv4.0:
cmv4.0: https://drive.google.com/file/d/1Ev16KY ... drive_link
cmv2.9: https://drive.google.com/file/d/1cINlFZ ... drive_link
