Problem playing MKV on LG 32LE5300
stidge
Post by stidge »
with the release 1.6.14 I have a problem playing the mkv in my LG 32le5300. The movie hangs for a short period every 3 seconds. When I edit thie MKV with mkv merge everything works fine. Please help....
File Info after makemkv
General
Unique ID : 251717154955592115570491518198546232842 (0xBD5EF5EB7CA01268B6D26C6E8784F60A)
Format : Matroska
Format version : Version 2
File size : 1.48 GiB
Duration : 42mn 17s
Overall bit rate : 5 027 Kbps
Encoded date : UTC 2011-07-02 15:21:33
Writing application : MakeMKV v1.6.10 win(x86-release)
Writing library : libmakemkv v1.6.10 (1.2.0/1.1.0) win(x86-release)
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Custom
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 42mn 17s
Bit rate mode : Variable
Bit rate : 4 543 Kbps
Maximum bit rate : 7 500 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.438
Stream size : 1.34 GiB (90%)
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 42mn 17s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -87ms
Stream size : 116 MiB (8%)
Title : 3/2+1
Language : German
Menu
00:00:00.000 : en:Chapter 01
00:04:01.047 : en:Chapter 02
00:10:55.047 : en:Chapter 03
00:14:06.767 : en:Chapter 04
00:16:35.647 : en:Chapter 05
00:18:45.767 : en:Chapter 06
00:22:32.807 : en:Chapter 07
00:25:42.247 : en:Chapter 08
00:29:52.607 : en:Chapter 09
00:31:38.807 : en:Chapter 10
00:35:10.407 : en:Chapter 11
00:38:39.567 : en:Chapter 12
Here the file info after mkvmerge
General
Unique ID : 242342180554026278824945851946255415170 (0xB65167FECD23E396A7A8B799684A7782)
Format : Matroska
Duration : 42mn 17s
Encoded date : UTC 2011-08-28 11:37:35
Writing application : mkvmerge v4.9.1 ('Ich will') gebaut am Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : MPEG Video
Codec ID : V_MPEG2
Duration : 42mn 17s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Language : German
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 42mn 17s
Bit rate : 384 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : German
Menu
crowfax
Re: Problem playing MKV on LG 32LE5300
Post by crowfax »
stidge wrote:Writing application : MakeMKV v1.6.10 win(x86-release)
Update to 1.6.14: http://makemkv.com/download/
stidge
Post by stidge »
Sorry, the file above was build with 1.6.10 but I have the same problem with 1.6.14.
stidge
Post by stidge »
Here the file informations made by mkvinfo
File with makemkv
(MKVInfo) + EBML-Kopf
(MKVInfo) |+ EBML-Version: 1
(MKVInfo) |+ EBML Leseversion: 1
(MKVInfo) |+ Maximale EBML-ID-L?¤nge: 4
(MKVInfo) |+ Maximale L?¤nge des EBML-L?¤ngenattributes: 8
(MKVInfo) |+ Dokumententyp: matroska
(MKVInfo) |+ Dokumententyp Version: 2
(MKVInfo) |+ Dokumententyp Leseversion: 2
(MKVInfo) + Segment, Gr?¶??e 1635983794
(MKVInfo) |+ Seek-Kopf
(MKVInfo) | + Seek-Eintrag
(MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) | + Seek-Position: 1113
(MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) | + Seek-Position: 1250
(MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) | + Seek-Position: 1635907920
(MKVInfo) | + Seek ID: 0x10 0x43 0xa7 0x70 (KaxChapters)
(MKVInfo) | + Seek-Position: 3166
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 1021)
(MKVInfo) |+ Segment-Information
(MKVInfo) | + Zeitstempelskalierungsfaktor: 1000000
(MKVInfo) | + Muxeranwendung: libmakemkv v1.6.14 (1.2.0/1.1.0) win(x64-release)
(MKVInfo) | + Schreibende Anwendung: MakeMKV v1.6.14 win(x64-release)
(MKVInfo) | + Dauer: 2534.607s (00:42:14.607)
(MKVInfo) | + Datum: Sun Aug 28 16:03:30 2011 UTC
(MKVInfo) | + Segment-UID: 0x0c 0xb9 0x53 0x41 0xf4 0xd9 0x75 0xc0 0xa4 0xa3 0x8f 0x3f 0x7a 0x57 0x52 0xc9
(MKVInfo) |+ Segment-Tracks
(MKVInfo) | + Ein Track
(MKVInfo) | + Tracknummer: 1
(MKVInfo) | + Track UID: 1
(MKVInfo) | + Tracktyp: video
(MKVInfo) | + Flag f??r Paketb??ndelung: 0
(MKVInfo) | + MinCache: 2
(MKVInfo) | + Codec-ID: V_MPEG2
(MKVInfo) | + private Codecdaten, L?¤nge 152
(MKVInfo) | + Standarddauer: 40.000ms (25.000 Bilder pro Sekunde im Falle eines Videotracks)
(MKVInfo) | + Video-Track
(MKVInfo) | + Pixelbreite: 720
(MKVInfo) | + Pixelh?¶he: 576
(MKVInfo) | + Anzeigebreite: 1024
(MKVInfo) | + Anzeigeh?¶he: 576
(MKVInfo) | + Tracknummer: 2
(MKVInfo) | + Track UID: 2
(MKVInfo) | + Tracktyp: audio
(MKVInfo) | + Codec-ID: A_AC3
(MKVInfo) | + Sprache: ger
(MKVInfo) | + Standarddauer: 32.000ms (31.250 Bilder pro Sekunde im Falle eines Videotracks)
(MKVInfo) | + Name: 3/2+1
(MKVInfo) | + Audio track
(MKVInfo) | + Abtastrate: 48000
(MKVInfo) | + Kan?¤le: 6
(MKVInfo) | + Tracknummer: 3
(MKVInfo) | + Track UID: 3
(MKVInfo) | + Tracktyp: subtitles
(MKVInfo) | + Codec-ID: S_VOBSUB
(MKVInfo) | + private Codecdaten, L?¤nge 509
(MKVInfo) | + Tracknummer: 4
(MKVInfo) | + Track UID: 4
(MKVInfo) | + Standardtrack-Flag: 0
(MKVInfo) | + Tracknummer: 5
(MKVInfo) | + Track UID: 5
(MKVInfo) |+ Kapitel
(MKVInfo) | + EditionEntry
(MKVInfo) | + EditionFlagHidden: 0
(MKVInfo) | + EditionFlagDefault: 1
(MKVInfo) | + EditionUID: 12915922310339309525
(MKVInfo) | + (Unbekanntes Element: EBMLVoid; ID: 0xec Gr?¶??e: 48)
(MKVInfo) | + ChapterAtom
(MKVInfo) | + ChapterUID: 6600988848267687528
(MKVInfo) | + ChapterTimeStart: 00:00:00.000000000
(MKVInfo) | + ChapterFlagHidden: 0
(MKVInfo) | + ChapterFlagEnabled: 1
(MKVInfo) | + ChapterDisplay
(MKVInfo) | + ChapterString: Chapter 01
(MKVInfo) | + ChapterLanguage: eng
(MKVInfo) | + ChapterUID: 5302647143292416574
(MKVInfo) | + ChapterTimeStart: 00:03:24.287977777
(MKVInfo) | + ChapterString: Chapter 02
(MKVInfo) | + ChapterUID: 5259777300638015384
(MKVInfo) | + ChapterTimeStart: 00:06:20.607977777
(MKVInfo) | + ChapterString: Chapter 03
(MKVInfo) | + ChapterUID: 5760466414679433918
(MKVInfo) | + ChapterTimeStart: 00:08:47.927977777
(MKVInfo) | + ChapterString: Chapter 04
(MKVInfo) | + ChapterUID: 15211834422386042834
(MKVInfo) | + ChapterTimeStart: 00:11:27.647977777
(MKVInfo) | + ChapterString: Chapter 05
(MKVInfo) | + ChapterUID: 15981302781094438331
(MKVInfo) | + ChapterTimeStart: 00:15:12.727977777
(MKVInfo) | + ChapterString: Chapter 06
(MKVInfo) | + ChapterUID: 8986237484827966272
(MKVInfo) | + ChapterTimeStart: 00:17:43.407977777
(MKVInfo) | + ChapterString: Chapter 07
(MKVInfo) | + ChapterUID: 16958650146549606241
(MKVInfo) | + ChapterTimeStart: 00:20:09.967977777
(MKVInfo) | + ChapterString: Chapter 08
(MKVInfo) | + ChapterUID: 10173933294178321389
(MKVInfo) | + ChapterTimeStart: 00:24:30.527977777
(MKVInfo) | + ChapterString: Chapter 09
(MKVInfo) | + ChapterUID: 16688510121909472696
(MKVInfo) | + ChapterTimeStart: 00:29:13.487977777
(MKVInfo) | + ChapterString: Chapter 10
(MKVInfo) | + ChapterUID: 3423498750120431433
(MKVInfo) | + ChapterTimeStart: 00:34:07.167977777
(MKVInfo) | + ChapterString: Chapter 11
(MKVInfo) | + ChapterUID: 18027791169878789527
(MKVInfo) | + ChapterTimeStart: 00:38:03.287977777
(MKVInfo) | + ChapterString: Chapter 12
(MKVInfo) |+ Cluster
File after mkvmerge
(MKVInfo) + Segment, Gr?¶??e 1598861539
(MKVInfo) | + Seek-Position: 4099
(MKVInfo) | + Seek-Position: 4249
(MKVInfo) | + Seek-Position: 1598787314
(MKVInfo) | + Seek-Position: 6819
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 4029)
(MKVInfo) | + Muxeranwendung: libebml v1.2.1 + libmatroska v1.1.1
(MKVInfo) | + Schreibende Anwendung: mkvmerge v4.9.1 ('Ich will') gebaut am Jul 11 2011 23:53:15
(MKVInfo) | + Dauer: 2474.648s (00:41:14.648)
(MKVInfo) | + Datum: Sun Aug 28 19:31:53 2011 UTC
(MKVInfo) | + Segment-UID: 0x9a 0x03 0x09 0x2e 0xaa 0xf0 0x32 0xf8 0xa3 0x3d 0x4c 0xab 0x5d 0xde 0x69 0x61
(MKVInfo) | + Inhaltskodierungen
(MKVInfo) | + Inhaltskomprimierung
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 1171)
(MKVInfo) | + EditionUID: 10513718927689726498
(MKVInfo) | + ChapterUID: 11071981707625861246
(MKVInfo) | + ChapterUID: 13907736328834604584
(MKVInfo) | + ChapterTimeStart: 00:03:16.607977777
(MKVInfo) | + ChapterUID: 2466260640834288163
(MKVInfo) | + ChapterTimeStart: 00:05:46.727977777
(MKVInfo) | + ChapterUID: 3476502681518425561
(MKVInfo) | + ChapterTimeStart: 00:10:06.447977777
(MKVInfo) | + ChapterUID: 11164657143329770977
(MKVInfo) | + ChapterTimeStart: 00:13:45.767977777
(MKVInfo) | + ChapterUID: 7706525193942486452
(MKVInfo) | + ChapterTimeStart: 00:18:11.447977777
(MKVInfo) | + ChapterUID: 12501520707523653492
(MKVInfo) | + ChapterTimeStart: 00:22:09.127977777
(MKVInfo) | + ChapterUID: 12088525475564576559
(MKVInfo) | + ChapterTimeStart: 00:26:00.887977777
(MKVInfo) | + ChapterUID: 7119766449340844920
(MKVInfo) | + ChapterTimeStart: 00:29:41.567977777
(MKVInfo) | + ChapterUID: 8575058931623154166
(MKVInfo) | + ChapterTimeStart: 00:31:27.567977777
(MKVInfo) | + ChapterUID: 13271784711923174234
(MKVInfo) | + ChapterTimeStart: 00:36:07.487977777
(MKVInfo) | + ChapterUID: 16762510866261496561
(MKVInfo) | + ChapterTimeStart: 00:38:23.687977777
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 101)
Post by mike admin »
Please do the following - open MKV file produced by MMG in MakeMKV 1.6.14, keep all tracks, and make another MKV file. Please post if the file still has issues.
stidge
Post by stidge »
It is not possible to open the file with makemkv 1.6.14....
German Error message : "Das ?ffnen der Disk schlug fehl"
