Partial / Incomplete MKV
WillyMk
Post by WillyMk » Wed Jun 12, 2024 5:30 am
I have a UHD disc that rips OK for about 99% and fails with just over 1 minute to go. Before it fails I made a copy of the incomplete MKV file. Is there anyway to "repair" this file so that the 99% that ripped can be played?
Re: Partial / Incomplete MKV
Post by dcoke22 » Thu Jun 13, 2024 2:03 am
I'm not aware of any way to do what you're asking.
Why does the rip fail? Maybe copy & paste your MakeMKV log into here.
WillyMk
Post by WillyMk » Thu Jun 13, 2024 3:23 am
It's a read error. I think the disc must have a scratch somewhere though I can't see it. I believe recovery should be possible. Particularly if you have another mkv that was formatted the same way (such as a TV series) to use as a reference. I've seen it done with MP4.
Its pretty rough to only have 1 min left of ripping and have an unusable file.
segfaulted
Post by segfaulted » Fri Jun 14, 2024 5:02 am
There's a decent chance you may be able to salvage an incomplete mkv rip from MakeMKV. Open the mkv in a hex editor (I use HxD) and see if the data starts with "This file was not properly finalized"
If it does say that, you can copy-paste this byte dump...
1A 45 DF A3 A3 42 86 81 01 42 F7 81 01 42 F2 81
04 42 F3 81 08 42 82 88 6D 61 74 72 6F 73 6B 61
42 87 81 02 42 85 81 02 18 53 80 67 01 00 60 00
00 00 00 00 11 4D 9B 74 44 7D 4D BB 92 53 AB 84
15 49 A9 66 53 AC 88 00 00 00 00 00 00 04 83 4D
BB 92 53 AB 84 16 54 AE 6B 53 AC 88 00 00 00 00
00 00 05 15 00 00 00 00 00 00 00 00 00 00 00 00
and replace the first 112 bytes of the mkv by pressing Ctrl-B (or right-click and "Paste write"). Make sure the cursor is at offset 0. Refer to the screenshot below for an example.
The mkv file probably won't play, but that's fine. You should be able to load it into mkvtoolnix's multiplexer to rebuild a working mkv file.
WillyMk
Post by WillyMk » Fri Jun 14, 2024 3:35 pm
segfaulted wrote: Fri Jun 14, 2024 5:02 am There's a decent chance you may be able to salvage an incomplete mkv rip from MakeMKV.
Thank you I will try.
