Zack Snyder's Justice League 4K UHD (UK)
Spearfish25
Re: Zack Snyder's Justice League 4K UHD (UK)
Post by Spearfish25 » Fri Dec 17, 2021 3:32 am
Anyone have luck with this? Just tried my disc one and it gave a bunch of errors and quit.
Crappusername
Post by Crappusername » Sat Nov 25, 2023 1:25 am
I just got the AU (I assume) version of this.
Disc 1 didn't work and I have submitted the dump
Disc 2 worked fine.
So it seems they only encrypted the first disc.
kevin040474
Post by kevin040474 » Sat Nov 25, 2023 1:55 am
my US copy works fine
then i joined the 2 parts together into 1 movie
tbrady3742@aol.com
Post by tbrady3742@aol.com » Thu Jun 06, 2024 10:01 pm
kevin040474 wrote: Sat Nov 25, 2023 1:55 am my US copy works fine
How did you join the two movies together to make one file? I want to use it for my Ben Hur that is in two separate files.
Post by dcoke22 » Thu Jun 06, 2024 10:18 pm
tbrady3742@aol.com wrote: Thu Jun 06, 2024 10:01 pm How did you join the two movies together to make one file? I want to use it for my Ben Hur that is in two separate files.
Most people would probably use MKVToolNix.
If your playback setup is Plex, Plex supports Movies Split Across Multiple Files.
tbrady3742@aol.com
Post by tbrady3742@aol.com » Wed Jun 12, 2024 3:06 am
dcoke22 wrote: Thu Jun 06, 2024 10:18 pm
I've got the MKVToolNix and I use Zappiti, actually I'm using R_Volution network. How would I use the MKVTool to combine the two files together? I have them both on HDD, so I would have to redownload them?
Post by d00zah » Wed Jun 12, 2024 10:20 am
tbrady3742@aol.com wrote: Wed Jun 12, 2024 3:06 am I've got the MKVToolNix and I use Zappiti, actually I'm using R_Volution network. How would I use the MKVTool to combine the two files together? I have them both on HDD, so I would have to redownload them?
From the bottom of the Plex link dcoke22 provided:
[HowTo]: joining multi-part movies files with MKVtoolnix GUI
tbrady3742@aol.com
Post by tbrady3742@aol.com » Mon Jun 17, 2024 3:13 am
d00zah wrote: Wed Jun 12, 2024 10:20 am
Hey, thanks for the assistance. It worked and now it is one complete file. Would have never been able to figure it out myself and couldn't get a direct answer from DVDfab about merging 2 files. Although they did show me how to make a DVD into a Blu-ray. Not as good as an original Blu-ray but not that bad. Sorry about taking this off subject but hopefully it has helped someone else. Now if I can get someone to reply to my question on the Godzilla Minus Zero about adding subtitles to the file, I would be golden. LOL Thanks again and have a great week.
Post by d00zah » Mon Jun 17, 2024 10:34 am
tbrady3742@aol.com wrote: Mon Jun 17, 2024 3:13 am ... Now if I can get someone to reply to my question on the Godzilla Minus Zero about adding subtitles to the file, I would be golden. LOL Thanks again and have a great week.
Couldn't find the referenced question, but use MakeMKVToolNix again...
- Drag the main video file into GUI.
- IF you already have separate subtitles * (.srt, etc), drag that into MKVToolNix GUI, too.
- Choose destination filename & hit 'Start Multiplexing'.
VERY simple.
* OpenSubtitles is a good source for finding missing subs.
tbrady3742@aol.com
Post by tbrady3742@aol.com » Wed Jun 19, 2024 3:02 am
d00zah wrote: Mon Jun 17, 2024 10:34 am
VERY simple.
thanks, but it actually had the subtitles in it. Don't know if you have gotten it or want to get Godzilla Minus One, but the movie is really good and the sound is awsome.
