oceans thirteen
mkv420
oceans thirteen
#1 Post by mkv420 » Thu Apr 23, 2009 4:36 am
When I tried to extract just the main stream (and all audio/subtitle tracks) from the original Ocean's Thirteen DVD, MakeMKV fails near the very end. I then extracted the whole disk using DVDFab5HD and pointed MakeMKV at the IFO in video_ts. Unfortunately this didn't work either (I would provide debug output, but MakeMKV locks up and pegs one core at 100%). Anyone else having issues with this disk (or similar issues with other disks)? Solutions?
Loving MakeMKV - keep up the great work!
mkv420
Re: oceans thirteen
#2 Post by mkv420 » Wed May 06, 2009 5:48 am
This problem is still present in 1.4.2 When MakeMKV freezes (shows "not responding" in the title bar and indeed does not respond) and deletes the partial mkv, the output size shows "4058.1 M". Let me know if there is anything I can do to help.
aloshka
Re: oceans thirteen
#3 Post by aloshka » Tue Sep 21, 2010 5:50 am
Hey same exact thing happens to me with the same movie, except I'm on a mac. It pretty much reaches 100%..
Log looks like...
MakeMKV v1.6.0 darwin(x86-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-898 HC10' at offset '1048576'
Title #0 was added (34 cell(s), 2:01:44)
Title #1 has length of 12 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #2 has length of 12 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #3 has length of 21 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #4 has length of 7 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #5 has length of 1366 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #6 has length of 274 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #7 has length of 497 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Title #8 has length of 144 seconds which is less than minimum title length of 2700 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Videos/Movies
Failed to save title 0 to file /Volumes/Videos/Movies/t00_OCEANS_THIRTEEN.mkv
0 titles saved, 1 failed
Saving 1 titles into directory /Users/aloshka/Desktop
Failed to save title 0 to file /Users/aloshka/Desktop/t00_OCEANS_THIRTEEN.mkv
Re: oceans thirteen
#4 Post by mike admin » Tue Sep 21, 2010 7:49 am
Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and post it here.
aloshka
Re: oceans thirteen
#5 Post by aloshka » Sun Oct 24, 2010 2:12 am
I tried, but it locks up at 80% when debugging turned on... should I just wait it out?
aloshka
Re: oceans thirteen
#6 Post by aloshka » Mon Oct 25, 2010 3:34 am
Left it running for 2 hours, fans running at full speed, application still locked up. Force quitted it, and no log file was generated. Disabling debug load, still causes same error. I can upload the movie VIDEO_TS files if you need to test somehow.
setarip_old
Re: oceans thirteen
#7 Post by setarip_old » Mon Oct 25, 2010 4:59 am
@aloshka
Hi!
Try changing the "minimum filesize" to (original default) 120 seconds, or less.
Clean your original DVD
If that doesn't resolve your problem, I'd suggest you return the DVD to the place of purchase, in exchange for a new replacement.
Re: oceans thirteen
#8 Post by mike admin » Mon Oct 25, 2010 5:50 am
Firstly, please see if 1.6.2 works on this disc. If it still locks up, please use command-line version to copy all titles and send produces debug log
makemkvcon mkv disc:0 all c:\temp
paulster
Re: oceans thirteen
#9 Post by paulster » Sun Aug 28, 2011 6:56 am
Did anyone ever find a solution to this particular disc issue? I've just encountered it today using 1.6.14 and get the failed error right at the end from the original DVD and from ISOs created by two different applications.
I tried using the debug option and, after 10 hours, found MakeMKV pegging a CPU at 100% and about 22MB of log file.
Re: oceans thirteen
#10 Post by mike admin » Wed Aug 31, 2011 9:32 am
This should have been fixed long ago. Please see PM.
jabba359
Re: oceans thirteen
#11 Post by jabba359 » Wed Aug 31, 2011 11:02 pm
Just gave Ocean's 13 a try and it worked fine for me. No problems at all.
