Recommendation for best (most reliable and versatile) LibreDrive for 2024?
abrooks98
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Post by abrooks98 »
Coopervid wrote: Sat Jun 08, 2024 6:02 pm
abrooks98 wrote: Sat Jun 08, 2024 4:26 pm
Coopervid wrote: Sat Jun 08, 2024 9:36 am
Read your PM.
Thanks! I am purchasing your suggestion.
Regarding the flasher you mentioned, can it be run on Linux?
You will need a Windows PC.
Thanks for clarifying. Would you have a recommended enclosure? Or should any USB enclosure suffice?
Post by d00zah »
abrooks98 wrote: Sun Jun 09, 2024 5:13 pm ...
The Ultimate UHD Drives Flashing Guide Updated 2023 says:
... for now any USB devices that works with optical drives should be able to flash them...
2dfx_ wrote: Sun Jun 09, 2024 4:39 pm
Coopervid wrote: Fri Jun 07, 2024 8:42 pm
redboyle wrote: Fri Jun 07, 2024 8:24 pm
I got the drive and the enclosure only thing I'm waiting for is the adapter for the powerplug that will arrive tomorrow.
Check your PM
Any suggestions for 5 1/4 drives from Canada?
Check your PM.
KenzieAon
Post by KenzieAon »
Coopervid wrote: Sun Jun 09, 2024 8:25 am
KenzieAon wrote: Sat Jun 08, 2024 9:30 pm
Could I get that PM?
You need to tell what you have or what you want plus your country of residence.
5 1/4" bay, USA is what I have and where I'm at
KenzieAon wrote: Mon Jun 10, 2024 1:02 am
Read your PM.
Tulip
Post by Tulip »
I'm about to get a new laptop, on which I plan to run Arch Linux. Are there any good options for external drives which will work with that setup? (I'm in the USA.)
Warning: PMs older than a week and not read will be deleted.
Tulip wrote: Mon Jun 10, 2024 4:33 pm I'm about to get a new laptop, on which I plan to run Arch Linux. Are there any good options for external drives which will work with that setup? (I'm in the USA.)
You need someone else to answer. Options are based on Windows.
ILPlais
Post by ILPlais »
Hello there,
I live in France, and would like to have some recommendations for external Blu-ray players, to play Blu-rays coming from all over the world.
This is to be used both on a laptop and a desktop computer, on which there is no place for an internal drive.
Thank you for your help. ;)
Altkey
Post by Altkey »
Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks. :)
Post by d00zah »
Altkey wrote: Thu Jun 13, 2024 8:33 am Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks. :)
viewtopic.php?p=154264#p154264
Altkey
Post by Altkey »
d00zah wrote: Thu Jun 13, 2024 12:45 pm
I don’t see that model listed exactly, but sounds like it would be considered part of the ‘junk that you hope works’?
Altkey wrote: Thu Jun 13, 2024 3:15 pm
Well there's actually 2 variants of that drive one is an LG other is a pioneer but no way to know what your getting
wibbl3
Post by wibbl3 »
Coopervid wrote: Sun Jun 02, 2024 12:11 pm
wibbl3 wrote: Sun Jun 02, 2024 11:14 am
Coopervid wrote: Sun Jun 02, 2024 10:59 amThe assumption is that he received a bad batch since he also sells that drive again. Look for the Verbatim that says 43888 in the description in Amazon. It will play UHDs right out-of-the-box. Beware: It's very power hungry and might not work with all USB3 ports. You might need a powered USB hub. And yes, the enclosure electronics is not the best and I have read that some failed while the internal drive was still OK.
Thank you. I can also get ahold of the BDR-212V for around the same cost. A better choice? I already have have usb converters that work with other optical drives.
This drive is very reliable. Get it and post again when you have it. You will being helped with it.
I got the 212V, but I said so in another post so you probably overlooked it. :oops:
viewtopic.php?p=153998#p153998
wibbl3 wrote: Thu Jun 13, 2024 10:54 pm
Check your PM.
