Thanks for clarifying. Would you have a recommended enclosure? Or should any USB enclosure suffice?
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
The Ultimate UHD Drives Flashing Guide Updated 2023 says:abrooks98 wrote: Sun Jun 09, 2024 5:13 pm ...
... for now any USB devices that works with optical drives should be able to flash them...
Check your PM.
I'm about to get a new laptop, on which I plan to run Arch Linux. Are there any good options for external drives which will work with that setup? (I'm in the USA.)
Warning: PMs older than a week and not read will be deleted.
You need someone else to answer. Options are based on Windows.Tulip wrote: Mon Jun 10, 2024 4:33 pm I'm about to get a new laptop, on which I plan to run Arch Linux. Are there any good options for external drives which will work with that setup? (I'm in the USA.)
Hello there,
I live in France, and would like to have some recommendations for external Blu-ray players, to play Blu-rays coming from all over the world.
This is to be used both on a laptop and a desktop computer, on which there is no place for an internal drive.
Thank you for your help.
Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks.
viewtopic.php?p=154264#p154264Altkey wrote: Thu Jun 13, 2024 8:33 am Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks.![]()
I don’t see that model listed exactly, but sounds like it would be considered part of the ‘junk that you hope works’?d00zah wrote: Thu Jun 13, 2024 12:45 pmviewtopic.php?p=154264#p154264Altkey wrote: Thu Jun 13, 2024 8:33 am Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks.![]()
Well there's actually 2 variants of that drive one is an LG other is a pioneer but no way to know what your gettingAltkey wrote: Thu Jun 13, 2024 3:15 pmI don’t see that model listed exactly, but sounds like it would be considered part of the ‘junk that you hope works’?d00zah wrote: Thu Jun 13, 2024 12:45 pmviewtopic.php?p=154264#p154264Altkey wrote: Thu Jun 13, 2024 8:33 am Hello, I'm located in the United States and looking for an external (5.25" or slim) UHD drive. Is the ASUS BW-16D1X-U a good option? Thanks.![]()
I got the 212V, but I said so in another post so you probably overlooked it.Coopervid wrote: Sun Jun 02, 2024 12:11 pmThis drive is very reliable. Get it and post again when you have it. You will being helped with it.wibbl3 wrote: Sun Jun 02, 2024 11:14 amThank you. I can also get ahold of the BDR-212V for around the same cost. A better choice? I already have have usb converters that work with other optical drives.Coopervid wrote: Sun Jun 02, 2024 10:59 amThe assumption is that he received a bad batch since he also sells that drive again. Look for the Verbatim that says 43888 in the description in Amazon. It will play UHDs right out-of-the-box. Beware: It's very power hungry and might not work with all USB3 ports. You might need a powered USB hub. And yes, the enclosure electronics is not the best and I have read that some failed while the internal drive was still OK.
viewtopic.php?p=153998#p153998
Check your PM.wibbl3 wrote: Thu Jun 13, 2024 10:54 pmI got the 212V, but I said so in another post so you probably overlooked it.Coopervid wrote: Sun Jun 02, 2024 12:11 pmThis drive is very reliable. Get it and post again when you have it. You will being helped with it.wibbl3 wrote: Sun Jun 02, 2024 11:14 am
