DerWom
Post
by DerWom » Fri Jun 07, 2024 2:34 pm
LordByron_ wrote: Wed Jun 05, 2024 5:09 pm
Hey, I live in Germany and if anyone has some time, would love to get a recommendation for a usb drive and a 5,25" one. Thank you in advance
I bought the Verbatim 43888 a couple of days ago; be carefull not to buy a 43889 (box looks very similar).
43888 works out-of-the box.
First try gave me SCSI errors - maybe the other usb port hasn't provided enough power. (I use a very small nuc)
redboyle
Post
by redboyle » Fri Jun 07, 2024 8:24 pm
Coopervid wrote: Wed Jun 05, 2024 8:58 pm
Read your PM.
I got the drive and the enclosure only thing I'm waiting for is the adapter for the powerplug that will arrive tomorrow.
Post
by Coopervid » Fri Jun 07, 2024 8:42 pm
redboyle wrote: Fri Jun 07, 2024 8:24 pm
Read your PM.
Check your PM
Post
by Coopervid » Fri Jun 07, 2024 8:44 pm
Link for ambishooter deleted since PM was not read.
abrooks98
Post
by abrooks98 » Fri Jun 07, 2024 9:22 pm
Hey Cooper, I was wondering if you have any suggestions for me. I am in the US and looking for a second internal drive. I have a WH16NS60 which works okay, but is prone to SCSI errors. UHD support would be nice, but isn't completely necessary.
gilfoyle
Post
by gilfoyle » Sat Jun 08, 2024 8:59 am
I am also from Germany. I would need some guidance too but I am unable to send you a pm. Could you maybe start a conversation?
Thanks in advance!
gilfoyle on Sat Jun 08, 2024 9:52 am, edited 1 time in total.
Post
by Coopervid » Sat Jun 08, 2024 9:36 am
abrooks98 wrote: Fri Jun 07, 2024 9:22 pm
Read your PM.
Post
by Coopervid » Sat Jun 08, 2024 12:12 pm
gilfoyle wrote: Sat Jun 08, 2024 8:59 am
Thanks in advance!
Check your PM.
gilfoyle
Post
by gilfoyle » Sat Jun 08, 2024 4:02 pm
Coopervid wrote: Sat Jun 08, 2024 12:12 pm
Thanks in advance!
Check your PM.
Thank you for the quick response. I ordered the external one.
Have a nice weekend!
abrooks98
Post
by abrooks98 » Sat Jun 08, 2024 4:26 pm
Coopervid wrote: Sat Jun 08, 2024 9:36 am
Read your PM.
Thanks! I am purchasing your suggestion.
Regarding the flasher you mentioned, can it be run on Linux?
Post
by Coopervid » Sat Jun 08, 2024 6:02 pm
abrooks98 wrote: Sat Jun 08, 2024 4:26 pm
Read your PM.
You will need a Windows PC.
redboyle
Post
by redboyle » Sat Jun 08, 2024 8:32 pm
Coopervid wrote: Fri Jun 07, 2024 8:42 pm
Read your PM.
Check your PM
thank you very much everything worked
KenzieAon
Post
by KenzieAon » Sat Jun 08, 2024 9:30 pm
Check your PM.
Could I get that PM?
Post
by Coopervid » Sun Jun 09, 2024 8:25 am
KenzieAon wrote: Sat Jun 08, 2024 9:30 pm
Check your PM.
You need to tell what you have or what you want plus your country of residence.
2dfx_
Post
by 2dfx_ » Sun Jun 09, 2024 4:39 pm
Read your PM.
Check your PM
Any suggestions for 5 1/4 drives from Canada?
