Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Stemdot9
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
#16 Post by Stemdot9 » Wed Jun 05, 2024 12:36 am
Is it possible to get my drive working too?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.05
Serial number: CCDL9100xxxx
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: Pioneer RS8D30
Firmware version: GENE
#17 Post by Billycar11 » Wed Jun 05, 2024 1:24 am
Stemdot9 wrote: Wed Jun 05, 2024 12:36 am Is it possible to get my drive working too?
OS device name: E:
Revision: 1.05
nah sorry man needs to be before 12/22 i recommend you return it a buy a pioneer with old fw from a seller in your region
Clicks
#18 Post by Clicks » Wed Jun 05, 2024 3:31 pm
Coopervid wrote: Fri Jan 12, 2024 4:43 pmCheck PM
Hi Coopervid, I have one of these and am also looking for the info on how to flash one of these for UHD support as well.
OS device name: /dev/sr0
Revision: 1.02
Serial number: SKDL002772UC
Firmware date: 2019-09-05
Highest AACS version: 78
Drive platform: RS8D30
Firmware version: 1.02
#19 Post by Coopervid » Wed Jun 05, 2024 4:38 pm
Check your PM.
Clicks
#20 Post by Clicks » Wed Jun 05, 2024 4:59 pm
Coopervid wrote: Wed Jun 05, 2024 4:38 pm Check your PM.
Worked like a charm, thank you so much!
Sungnib
#21 Post by Sungnib » Fri Jun 07, 2024 12:56 am
Hi. I'm on a Mac. This is my current external drive that works with MakeMKV with DVDs and regular blurays but not Ultra HD.
Is there a way to make it work?
Revision: 1.03
Serial number: BFDL037253UC
Firmware date: 2020-08-20
Firmware version: 1.03
Thanks in advance
inlandchris
#22 Post by inlandchris » Fri Jun 07, 2024 10:44 am
Hi guys,
I have a Pioneer BD-RW BDR-S12U and I am having trouble and I don't know why. It worked 1 week ago but now, "failed to open disc"
Drive and UHD info:
OS device name: F:
Product: BD-RW BDR-S12U
Revision: 1.03
Serial number: AKDL003191WL
Firmware date: 2022-10-13
Highest AACS version: 77
Drive platform: RS8F01
Firmware version: 1.03/ID43
Disc Information
Label: DUNE_PART_TWO
Timestamp: 2024-03-23 14:26:32
Protection: AACS2.0/C v77
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
This one worked 1 week ago!
Disc Information
Label: ENTER_THE_DRAGON
Timestamp: 2023-07-19 13:09:03
Data capacity: 80.50 Gb
Number of layers: 3
I upgraded to the latest MakeMKV version and still have the same problem
Is there anybody out there that has a fix?
Best,
Craig
:D
#23 Post by Coopervid » Fri Jun 07, 2024 11:45 am
You would need to connect it to a Windows computer.
jkboyo
#24 Post by jkboyo » Fri Jun 07, 2024 4:58 pm
Hi. I would like to get one of the pioneers as I hear they are the best but from what I can tell we're only giving flashing info over PM's. B4 I go and buy one would I be able to get this info so I can know what's going on B4 buying one?
inlandchris
#25 Post by inlandchris » Sat Jun 08, 2024 5:50 am
Coopervid wrote: Fri Jun 07, 2024 11:45 am You would need to connect it to a Windows computer.
I am,
Here is a debug code:
Debug log started at Sat Jun 08 05:24:34 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\inlan/MakeMKV_log.txt
Using 1048320KB for read cache.
003338:0000 Downloading latest SDF to E:/Movies/DebugLog ...
001003:0020 DEBUG: Code 4279336967 at #RR.[3VW3f!jtf":121262877
003339:0000 Automatic SDF downloading is disabled or failed.
001003:0020 DEBUG: Code 152 at vtE<(>?]*E!<z7r!:213144911
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF v097: PIONEER_BD-RW___BDR-S12U_1.03_AKDL003191WL
Application exited at Sat Jun 08 05:46:47 2024
What is SDF downloading? It looks like it failed, could this be a problem and how to fix it?
thanks in advance
Craig
:D
inlandchris
#26 Post by inlandchris » Sat Jun 08, 2024 6:03 am
Sorry to bother you again but I did find out what was wrong: the Windows firewall block an ip that Makemkv is using but don't know which one, would you know?
best,
Craig
:D
#27 Post by Coopervid » Sat Jun 08, 2024 7:20 pm
inlandchris wrote: Sat Jun 08, 2024 6:03 am
best,
Craig
Try to ping these:
viewtopic.php?f=1&t=20851
#28 Post by Coopervid » Sat Jun 08, 2024 8:51 pm
jkboyo wrote: Fri Jun 07, 2024 4:58 pm Hi. I would like to get one of the pioneers as I hear they are the best but from what I can tell we're only giving flashing info over PM's. B4 I go and buy one would I be able to get this info so I can know what's going on B4 buying one?
Country of residence?
jkboyo
#29 Post by jkboyo » Sun Jun 09, 2024 1:18 pm
Coopervid wrote: Sat Jun 08, 2024 8:51 pm
USA
#30 Post by Coopervid » Sun Jun 09, 2024 7:32 pm
jkboyo wrote: Sun Jun 09, 2024 1:18 pm
USA
Check you PM.
