Hey folks,
Long-time makemkv forum reader, first-time poster. I was recently inspired by some other posts on this forum to invest in a 4K-compatible drive and read folks mention that the Verbatim 43888 works "out of the box" -- recently imported from the UK into the states and it put me back about $120 (aside from the problems following, this wasn't the worst deal ever): https://www.amazon.co.uk/dp/B07MTP9VKX
Anyway, I loaded this up in MakeMKV and the Info seemed to read exactly as I've seen in other folks' posts:
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
Unfortunately, when I put in any 4K disk, it just says "No disc inserted." It reads DVDs just fine but it hasn't read any of the five 4K disks I've tried. I feel like this problem is probably outside MakeMKV, but I'm out of ideas and hoping someone has a theory! Anyone know what I should try?
Verbatim 43888 "No disc inserted"
Re: Verbatim 43888 "No disc inserted"
Did you test a standard BD disc?Patappa wrote: Fri Jun 07, 2024 10:59 pm Hey folks,
OS device name: I:
Revision: 1.14
Patappa
Looks like normal blu-rays are having the same problem as 4K's and also coming up with "no disc inserted."
Before I had only tested with American blu-rays and it didn't work but I assumed it was because this was a region B player, but now I've just tried with an all-region disk from Indicator and it also did not work.
Maybe the blue laser is no good??Patappa wrote: Sat Jun 08, 2024 3:06 am Looks like normal blu-rays are having the same problem as 4K's and also coming up with "no disc inserted."
Does the OS see the BD disc?
Patappa
The OS does not seem to see the BD, nope...MartyMcNuts wrote: Sat Jun 08, 2024 10:47 pmMaybe the blue laser is no good??Patappa wrote: Sat Jun 08, 2024 3:06 am Looks like normal blu-rays are having the same problem as 4K's and also coming up with "no disc inserted."
Well, I guess I'll have to see what Verbatim support can do. I appreciate the theorizing -- I'll report back here in case other folks end up having similar problems with the 43888 in the future.
Might be easier to just return it.Patappa wrote: Sun Jun 09, 2024 2:23 amThe OS does not seem to see the BD, nope...MartyMcNuts wrote: Sat Jun 08, 2024 10:47 pmMaybe the blue laser is no good??Patappa wrote: Sat Jun 08, 2024 3:06 am Looks like normal blu-rays are having the same problem as 4K's and also coming up with "no disc inserted."
Does the OS see the BD disc?![]()
DerWom
Yep - that is excatly the drive I got.
Have you tried another USB Port ? I've seen errors on one port...
Patappa
I have! I've tried basically every port on three different computers and they've had the same issue: DVD's work fine but blu-ray and 4K disks don't. I think it's most likely a problem with the blue laser. Bums me out to get this kind of hardware issue considering returning it internationally is going to be annoying (already had a frustrating interaction with Verbatim support where they said importing it "makes no sense" because it "can be purchased within the USA")
X-dark
Was it fixed with a replacement or something else?
I have a similar issue with a new 43890 (Pioneer inside).
Edit: connecting the second USB (despite already having the power adapter plugged), it started to work.
