#9976 Post by MartyMcNuts » Sun Jun 02, 2024 1:11 am
Has anyone tried the AM8 Pro with the Amlogic S928X-J soc? Does this play DV P7 MEL/FEL mkv files via NAS streaming? Is it possible to dual boot and use CoreElec or LibreElec?
anta777
#9977 Post by anta777 » Sun Jun 02, 2024 11:38 am
@RESET_9999
Why DV5 better DV8 ?
True:
DV5 brightness 0-1023 chroma 0-1023
DV8 brightness 64-940 chroma 64-960
DV5=1,15*DV8 video bitrate.
Netflix DV5 video bitrate 17,5 Mbit.
Because DV8 videobitrate >20,125 Mbit better than DV5.
#9978 Post by RESET_9999 » Sun Jun 02, 2024 12:42 pm
it uses a more efficient colorspace.
https://youtu.be/DcN6a57DYAc?t=799
ArArdin
#9979 Post by ArArdin » Sun Jun 02, 2024 12:53 pm
I wonder if saying P5 is better over P8 just by comparing specs and bitrates is a real-world thing. Maybe it's more fair to express "better" in terms of perception of delivered quality. P5's full range and use of proprietary colorspace carrying potential, one still has to wait & see how bad/well this potential is used on delivery. Streaming services have horribly proofed themselves to - and still do - deliver terrible quality (and not only in DoVi) on a regular base. For this sake of lower bandwith they still simply often compress video too much. I have done some dovibaker x265 HDR encodings from disc-sourced material which quality obliterates that of any P5 stream of same video. Just saying. P8, MEL (and even FEL) are no guarantee to provide with a "better" picture of course, but in my viewing experience overall Dolby Vision quality on - or derived from - disc still rules. And not by a bit.
#9980 Post by RESET_9999 » Sun Jun 02, 2024 12:57 pm
yeah I agree. Streaming services have horrible encoding quality most of the time, especially itunes and Amazon. It's never just about the bitrate, the encode settings matter big time.
texwatson
#9981 Post by texwatson » Mon Jun 03, 2024 12:36 am
It's been tried. No Coreelec yet and no DV P7.
#9982 Post by MartyMcNuts » Mon Jun 03, 2024 2:53 am
Ok, thanks. I'll wait for a bit and hopefully it will be supported soon.
Mrmorrison
#9983 Post by Mrmorrison » Wed Jun 05, 2024 10:21 am
Hi everyone.
I have a TV that does not support LED TV. Nits less than 1000.
If I buy Ugoos, am I right? Or would LLDV be broken in my case?
Second question:
My TV is Android and with Kodi I can play all DV profiles up to 7 MEL. I would only use Ugoos for 7 Fel.
But if for example I have a dv 8 film, should I always prefer the internal app on the TV or can I choose Ugoos?
spl147
#9984 Post by spl147 » Wed Jun 05, 2024 12:35 pm
sofakng wrote:
Thu May 30, 2024 8:12 pm
If I understand correctly, the three best devices are the following:
UGOOS AM6B plus
UGOOS AM6 plus
Minix u22x-j max
Is this correct? What's the difference between them and is there any recommendation for the one best option?
UGOOS AM6B plus = WiFi6, Metal case better cooling, smaller footprint
UGOOS AM6 plus = WiFi5, Metal case better cooling, smaller footprint
Minix u22x-j max = WiFi5, Plastic case
the AM6B Plus can be had on Aliexpress for $160 shipped direct from Ugoos
kazuma
#9985 Post by kazuma » Wed Jun 05, 2024 3:36 pm
RESET_9999 how is your experience going with the ugoos? please inform us if you find new advantages/disadvantages. because you are most advanced user of the world of this box :D
#9986 Post by RESET_9999 » Wed Jun 05, 2024 3:55 pm
I updated the playback device spreadsheet just a few days ago, check it out
ArArdin
#9987 Post by ArArdin » Fri Jun 07, 2024 8:07 am
In the dual-track dual-layer support column, I noticed mkv being mentioned. Is DTDL possible in matroska nowadays?
#9988 Post by RESET_9999 » Fri Jun 07, 2024 11:03 am
It's supported when the 2nd layer has the dv flag (sidedata) and AFAIK, the only way to get that is by muxing a DT MP4.
ArArdin
#9989 Post by ArArdin » Fri Jun 07, 2024 1:51 pm
Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?
#9990 Post by RESET_9999 » Fri Jun 07, 2024 2:07 pm
1- mux a DT-DL MP4 in mkvtoolnix
2- mux raw hevc layers in mkvtoolnix but this produces a dvhe.07.03 file instead of dvhe.07.06
General
Complete name                            : D:\FEL TEST DT DL P7 CMV4.0 4000nits V3.mkv
File size                                : 25.3 MiB
Duration                                 : 1 min 0 s
Overall bit rate                         : 3 527 kb/s
Frame rate                               : 23.976 FPS
Writing application                      : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 3 165 kb/s
Bits/(Pixel*Frame)                       : 0.016
Stream size                              : 22.7 MiB (90%)
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 293 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.006
Stream size                              : 2.10 MiB (8%)
Complete name                            : D:\00000.track_4113.mkv
File size                                : 381 MiB
Overall bit rate                         : 52.8 Mb/s
Video #1
Bit rate                                 : 52.7 Mb/s
Bits/(Pixel*Frame)                       : 0.265
Stream size                              : 381 MiB (100%)
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 694 cd/m2
Maximum Frame-Average Light Level        : 61 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 69.3 kb/s
Bits/(Pixel*Frame)                       : 0.001
Stream size                              : 512 KiB (0%)
