Pioneer BDR-UD03 UHD possibility
onlybob
Re: Pioneer BDR-UD03 UHD possibility
Hi, here is the following information of my UD03 in a verbatim 70102 drive:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: Tacos&Tequila
Firmware date: 2018-11-28
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.11
Is this drive eligible to read UHDs? I appreciate you helping us all out with this, I scoured the forums and didnt find anything concrete for these drives, but had no issues flashing my LG drive thanks to the general guide.
Revision: 1.11
stickpin
I've received my PIONEER BD-RW BDR-UD03
Revision: 1.14
Any chance someone can help with getting right firmware for enabling UHD read?
Thanks a lot in advance!
Revision: 1.14
onlybob and stickpin: Read your PMs.
stickpin
Sorry, messages are being deleted.
I see this message: "You are not able to read this message because it was removed by the author."
onlybob
Guys. I have trouble with the links. They are not working. I try to fix this and you will receive new PMs.
Check now.
Link for nads deleted since it was not read.
onlybob
Thank you CooperVid, the flash went without any issue. This might warrant a different thread but would you know how to increase the read speed for standard blu rays? It maxes out at 2X and the pioneer software fails to recognize the drive to potentially unlock any riplocks. Noting the 4K rips at x4 as expected.
Again, your help is appreciated.
MisakaUmr
Hi, Coopervid I've got:
Revision: 1.00
Serial number: MIDL000318WL
Can I get help with getting right firmware for enabling UHD read?
Revision: 1.00
Read this:onlybob wrote: Fri Jun 07, 2024 10:37 pmThank you CooperVid, the flash went without any issue. This might warrant a different thread but would you know how to increase the read speed for standard blu rays? It maxes out at 2X and the pioneer software fails to recognize the drive to potentially unlock any riplocks. Noting the 4K rips at x4 as expected.
viewtopic.php?f=19&t=22689
clwelch63
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Firmware version: 1.10
OS device name: E:
Revision: 1.10
onlybob
Two for two, that did the trick as well, can't thank you enoughCoopervid wrote: Sat Jun 08, 2024 9:35 amRead this:onlybob wrote: Fri Jun 07, 2024 10:37 pmThank you CooperVid, the flash went without any issue. This might warrant a different thread but would you know how to increase the read speed for standard blu rays? It maxes out at 2X and the pioneer software fails to recognize the drive to potentially unlock any riplocks. Noting the 4K rips at x4 as expected.
dirtyrobinson
I'm here for the same reason. Can this read play UHD discs?
OS device name: G:
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 68
Firmware version: 1.14
OS device name: G:
Revision: 1.14
MeeStaKlean
Hello Coppervid
Hello, Can you please Message me the flash code for UD03. Here is the screenshot of the drive.
https://ibb.co/9GXjYgw
