AACS 2.1 support
xmenw
Re: AACS 2.1 support
#121 Post by xmenw » Wed Jul 08, 2020 4:18 am
It seems like Charlie's Angels (2000) is AACS 2.1, I was able to successfully back up the disc, my oppo 203 bring up the menu, and when I start playing the movie, the player is unable to play the movie, and I'm stuck at the black screen.
Is there anything else that needs to be done? This is my first decrypted backup for a full disc with AACE 2.1
EDIT: This is an error on my side, I had reinstalled MakeMKV and I believe the decrypt backup option was unchecked, doing it again and will report back.
xunil76
#122 Post by xunil76 » Mon Oct 24, 2022 4:20 am
OK, so I just spent the last couple hours reading this entire thread (and trying to understand only the relevant info for me), in order to create a backup of my Zombieland AACS2.1 4K UHD disc that I recently purchased (the steelbook version containing both the 4K UHD and the 1080p blu-ray copies), and I "think" I have the process down for what I'm trying to do, but I just wanted to double-check first. I want to create an ISO image of the disc first (forget about the 'why', that part is not important for this discussion), then I will run that ISO image through MakeMKV in order to rip out only the main movie (for now), which I can then use to encode the movie before storing it on my Media Server NAS. Please let me know if these steps will work, if I'm missing any steps, or any steps are incorrect:
1) Put the 4K UHD disc into the drive and let the drive/O.S. do the initial read of the disc
2) Open MakeMKV, select the correct drive (if you have multiple drives like I do, and "Ask for single drive mode" is enabled), then once it has detected that the disc is in the drive, press the "drive button" in an attempt to read the contents of the disc (which will fail if it is using AACS 2.1)
3) Ensure that after pressing the button to read the disc, the status text says "Using LibreDrive mode (v06.x id=xxxxxxxx)" (which indicates that LibreDrive access has been enabled), and "Using direct disc access mode" (indicating that bus encryption has been disabled)
4) Open ISO image creation software of your choice (in my case, ImgBurn) and create an ISO image of the disc in that drive, which "should" be bit-perfect to the disc, minus any bus encryption data.
5) Mount the resulting ISO image, then open that virtual drive using MakeMKV to have it decrypt the titles and allow ripping of the main title to .mkv format, ready for encoding.
I've attached a screenshot of what needs to be done in step 2) to enabled LibreDrive mode, as well as exactly what to look for in step 3); it is required that this information be seen before any ISO being created will be worth anything.
One question...does this MakeMKV window need to remain open while creating the ISO image, or will LibreDrive mode/direct disc mode remain active until such time as the disc has been ejected? (the way I understand it, the latter is the case, and MakeMKV can be closed after getting those messages, but please correct me if I'm wrong).
Screenshot for step 2):
Enabling LibreDrive Mode Via GUI.png (60.77 KiB) Viewed 94744 times
Screenshot for step 3):
LibreDrive Mode Enabled.png (11.31 KiB) Viewed 94744 times
If the above is all correct, then there is something wrong, because MakeMKV is not able to decrypt the data from the resulting ISO image file. I'm using Daemon Tools Lite to mount the ISO image. I get the following when MakeMKV tries to read the virtual disc (latest version of DVDFab is also unable to decrypt it):
MakeMKV Decryption Error.png (38.04 KiB) Viewed 94744 times
xunil76
#123 Post by xunil76 » Mon Oct 24, 2022 4:38 am
also, the attached screenshot is what I get when I try to load the ISO image file directly, without taking the intermediate step of mounting in Daemon Tools Lite first:
MakeMKV Decryption Error (Direct ISO Access).png (6.01 KiB) Viewed 94743 times
#124 Post by MartyMcNuts » Mon Oct 24, 2022 5:15 am
xunil76 wrote: Mon Oct 24, 2022 4:20 am OK, so I just spent the last couple hours reading this entire thread (and trying to understand only the relevant info for me), in order to create a backup of my Zombieland AACS2.1 4K UHD disc that I recently purchased (the steelbook version containing both the 4K UHD and the 1080p blu-ray copies), and I "think" I have the process down for what I'm trying to do, but I just wanted to double-check first. I want to create an ISO image of the disc first (forget about the 'why', that part is not important for this discussion), then I will run that ISO image through MakeMKV in order to rip out only the main movie (for now), which I can then use to encode the movie before storing it on my Media Server NAS. Please let me know if these steps will work, if I'm missing any steps, or any steps are incorrect:
It looks like there is no VUK for your disc version. Please submit the AACS dump file that was created. I also suggest you read this thread: viewtopic.php?f=12&t=20549
xunil76
#125 Post by xunil76 » Tue Oct 25, 2022 4:05 am
MartyMcNuts wrote: Mon Oct 24, 2022 5:15 am
dump file submitted...does my methodology look correct, though? just want to make sure i'm not missing anything.
#126 Post by MartyMcNuts » Tue Oct 25, 2022 4:58 am
xunil76 wrote: Tue Oct 25, 2022 4:05 am
Yeah, although step 2 shouldn't fail as MakeMKV is compatible with AACS 2.1. There are only certain versions of Zombieland UHD that there aren't yet VUK's for. I'm not sure if yours is one of those versions or not.
The other way to do it is to use MakeMKV to rip the disc to a decrypted folder, then if you need an iso, create the iso from the decrypted folder.
binaryflow
#127 Post by binaryflow » Sat Jun 03, 2023 2:52 am
Are those Zombieland versions supported now? I want to buy it.
outlier
#128 Post by outlier » Tue Aug 08, 2023 8:18 am
binaryflow wrote: Sat Jun 03, 2023 2:52 am Are those Zombieland versions supported now? I want to buy it.
My Zombieland still doesn’t work (dump file was previously submitted).
Matti
#129 Post by Matti » Sun Nov 05, 2023 9:35 am
I submitted dump for my copy of Zombieland.
MKB21_v70_Zombieland_0C04.tgz
It was >20mb in size, so the only way I could sent is from Gmail was as a Google Drive link. Wondering if that is fine? Do not really have an email account that could send files that large directly.
patpro
#130 Post by patpro » Sun Dec 10, 2023 7:32 am
Here is the AACS dump for Titanic 4K UHD that was recently released.
ethermole
#131 Post by ethermole » Mon May 06, 2024 2:49 pm
mike admin wrote: Fri Dec 06, 2019 8:33 pm
Coopervid wrote: Fri Dec 06, 2019 7:51 pm I think the answer is quite easy. Making a protected ISO and then mounting it with either Windows 10 or any other tool gives us the opportunity to decrypt it with whatever software that is capable to decrypt this disc first. Be it your software or your competitor's. Sometimes your program is first, sometimes the competition is first.
The ISO format has no means to save key-related metadata from the disc, and without such metadata it is impossible to decrypt the ISO when bus-encryption is not disabled (with LibreDrive for example).
Isn't that exactly what the 32kiB of reserved space at the head of ECMA-119 format is? Just create your own (non-standard) volume descriptor tag and fill it with whatever you want, and if you need that much space, just record the first address where you store that data in the ISO file and the length of that data, and append that data to the tail end of the ISO you've ripped...
mike admin wrote: Fri Dec 06, 2019 8:33 pm My first question is whether AnyDVD uses some sort of extension to save such metadata, and whether CloneDrive or whatever can use such metadata and emulate the protected disc. I honestly don't know, but I doubt it.
AFAIK, AnyDVD uses a magic signature for discs after bus encryption's removed.
Moe123
#132 Post by Moe123 » Thu Jun 06, 2024 5:19 pm
:mrgreen:
#133 Post by d00zah » Thu Jun 06, 2024 6:16 pm
Moe123 wrote: Thu Jun 06, 2024 5:19 pm Jackdaw UltraHD does not yet have support
MKB20_v77_JACKDAW_89C6
https://mega.nz/file/zBQwVSDD#_5iKGkAnb ... enkmRheblI
NOT an AACS 2.1 title. Just email the dump to svq@makemkv.com per the UHD FAQ (Hashed Keys section).
Mike_Copy_Di
#134 Post by Mike_Copy_Di » Tue Oct 29, 2024 3:33 am
Since my Mac has updated to Sequoia I have not been able to copy UHD discs.
Blu-Ray and DVD copy fine.
This had worked: PIONEER External Blu-ray Drive BDR-X13U-S Excellent Reliability & Stability 16x BD-R Writing Speed USB 3.2 Gen1 / 2.0 BD/DVD/CD Writer with PureRead 4+ Realtime PureRead X13U-S-USONLY-Model
Now with multiple UHD discs:
Help please
MakeMKV v1.17.7 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/mike/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-X13U 1.04 DDDL300587UCd" opened in OS access mode.
Backing up disc into folder "/Users/mike/Desktop/4AppleTV_Media/backup/LAST STARFIGHTER UHD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 0 at .2Eu>}/J"aW_RL#:l:213130766
DEBUG: Code 0 at F0=,^NgZzPq]vTs:g[:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 0 at F0=,^NgZzPq]vTs:g[:213131686
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 1 at F0=,^NgZzPq]vTs:g[:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 1 at F0=,^NgZzPq]vTs:g[:213131686
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 2 at F0=,^NgZzPq]vTs:g[:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 2 at F0=,^NgZzPq]vTs:g[:213131686
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 3 at F0=,^NgZzPq]vTs:g[:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 3 at F0=,^NgZzPq]vTs:g[:213131686
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 0 at F0=,^NgZzPq]vTs:g[:213130789
Saved AACS dump file as /Users/mike/Library/MakeMKV/MKB20_v77_LAST_STARFIGHTER_UHD_28F6.tgz
DEBUG: Code 0 at jl{+0X>9gGAfos~i:213132721
DEBUG: Code 0 at 4{X9vE3TVj63gva<,`i:121273319
DEBUG: Code 0 at WsC|cmJ80Jei;}:4-cz%:121265338
Backup failed
ryley
#135 Post by ryley » Sat Nov 09, 2024 8:25 am
Mike_Copy_Di wrote: Tue Oct 29, 2024 3:33 am Since my Mac has updated to Sequoia I have not been able to copy UHD discs.
Help please
Backup failed
Your drive firmware seems to have been updated to BDR-X13U 1.04. This update dates from September 2023. Currently no Pioneer firmware update released after November 2022 works with LibreDrive and there is no publicly documented way to downgrade back to a supported firmware.
Unfortunately I don’t believe there is anything you can do to recover UHD support for your drive at this point in time.
