trying to rip and or copy the dvd that comes with nine inch nails with teeth album. ( a cd/dvd combo) one side is cd one is dvd. these are the errors that show up after it fails.
iso bkup
MakeMKV v1.17.5 darwin(x64-release) started
Debug logging enabled, log will be saved as (...)
Optical drive "BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005088UCd" opened in OS access mode.
The new version 1.17.6 is available for download at http://www.makemkv.com/download/
DEBUG: Code 0 at 7N4m|hG$B.606"Wtpq.<{27Fi:29395149
Using LibreDrive mode (v01.0 id=1534D764B687)
Backing up disc into folder "/Users/(...)/Movies/WITH_TEETH.iso"
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
DEBUG: Code 0 at bW'o8T(k'!]d6vDT=1B|j7m:121263406
DEBUG: Code 52671 at }v?VtZ$Gc65;%`IT3.ab:213133250
DEBUG: Code 0 at }v?VtZ$Gc65;%`IT3.ab:121265062
DEBUG: Code 0 at }v?VtZ$Gc65;%`IT3.ab:29394689
DEBUG: Code 118095996 at bW'o8T(k'!]d6vDT=1B|j7m:29394183
DEBUG: Code 0 at bW'o8T(k'!]d6vDT=1B|j7m:121263590
DEBUG: Code 0 at V[Lu`^-W0B?m,_:29397104
DEBUG: Code 0 at z~[A^k6Wm<A(+s%rQ9)(:121266097
Backup failed
open files
Title #4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
