libredrive VERBATIM 43888
Good morning,
I am taking the liberty of writing to you because I want to install libredrive on VERBATIM 43888. I saw in the Amazon comments someone say that it is running on firmware 1.4 and that it would be libredrive compatible.
On the forum, I saw that it would be possible to switch it to LibreDrive.
But I can't find any firmware and method to do it.
Anyone to help me?
If it is not possible to install libredrive, recommend which external drive for 4K UDH blu-ray burner and playback?
I speak bad English, I have to use Google translate. I am French.
Thank you in advance.
Anyone to help me?
Re: libredrive VERBATIM 43888
I have the same drive with firmware version 1.14 and LibreDrive is already enabled. You should see the following in MakeMKV on the right.
Best install and post your Makemkv information for your drive. Someone can then advise on the way forward.
If it is a Verbatim 43888 it is already libredive and UHD compatible. And firmware is 1.14 not 1.4.HarryKleins wrote: ↑Wed Jun 05, 2024 4:04 pmGood morning,
Anyone to help me?
Hello,Coopervid wrote: ↑Wed Jun 05, 2024 5:29 pmIf it is a Verbatim 43888 it is already libredive and UHD compatible. And firmware is 1.14 not 1.4.HarryKleins wrote: ↑Wed Jun 05, 2024 4:04 pmGood morning,
Anyone to help me?
Yes indeed I was mistaken. It is indeed version 1.14.
When you say it is already libtedrive, does that mean I only use the MakeMKV software without installing custom firmware?
Correct.HarryKleins wrote: ↑Wed Jun 05, 2024 5:32 pmHello,Coopervid wrote: ↑Wed Jun 05, 2024 5:29 pmIf it is a Verbatim 43888 it is already libredive and UHD compatible. And firmware is 1.14 not 1.4.HarryKleins wrote: ↑Wed Jun 05, 2024 4:04 pmGood morning,
Anyone to help me?
Good morning,
Can you confirm that the drive is indeed in libredrive?
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-UD04
Révision : 1.14
Numéro de série : DADL129637WL
Date micrologiciel : 2020-06-15
Marqueurs d'encryptage bus : 1B
Drive platform: RS8A10
Firmware version: 1.14
Aucun disque
THANKS.
Fabricant : PIONEER
Révision : 1.14
Aucun disque
THANKS.
Put an UHD in it. Should work w/o any problem.
Sure enough, I'm ripping a blu-ray. Speed X4 17.1 M/S. It takes me about three hours for 88 GB. Is that a good speed?
Once the .MKV file is finished, I could play it with any player, correct?
Also, with the extraction, I get the menus and everything that goes with it?
Loss of quality?
MakeMKV, allows you to extract only blu-rays or DVDs and CDs while removing the DRM?
Thank you for your answers.
Loss of quality?
With the Verbatim (Pioneer inside), for a 90GB UHD disc, ripping the full disc to a decrypted folder usually takes around 1hr30min give or take a few.HarryKleins wrote: ↑Thu Jun 06, 2024 4:40 pmSure enough, I'm ripping a blu-ray. Speed X4 17.1 M/S. It takes me about three hours for 88 GB. Is that a good speed?
Loss of quality?
DVD/BD, yes, pretty much any player. UHD movies require a player capable of HDR.
If you create a full disc folder backup, it includes everything. If you rip to a mkv file, then you only get whatever titles you have selected as individual mkv files.
No loss of quality. MakeMKV is not an encoder. It just decrypts and extracts.
DVD/BD/UHD (with a compatible drive)
