Post by MartyMcNuts » Mon Jun 03, 2024 2:53 am
texwatson wrote: Mon Jun 03, 2024 12:36 am
MartyMcNuts wrote: Sun Jun 02, 2024 1:11 am Has anyone tried the AM8 Pro with the Amlogic S928X-J soc? Does this play DV P7 MEL/FEL mkv files via NAS streaming? Is it possible to dual boot and use CoreElec or LibreElec?
It's been tried. No Coreelec yet and no DV P7.
Ok, thanks. I'll wait for a bit and hopefully it will be supported soon.
Mrmorrison
Post by Mrmorrison » Wed Jun 05, 2024 10:21 am
Hi everyone.
I have a TV that does not support LED TV. Nits less than 1000.
If I buy Ugoos, am I right? Or would LLDV be broken in my case?
Second question:
My TV is Android and with Kodi I can play all DV profiles up to 7 MEL. I would only use Ugoos for 7 Fel.
But if for example I have a dv 8 film, should I always prefer the internal app on the TV or can I choose Ugoos?
spl147
Post by spl147 » Wed Jun 05, 2024 12:35 pm
sofakng wrote: Thu May 30, 2024 8:12 pm If I understand correctly, the three best devices are the following:
UGOOS AM6B plus
UGOOS AM6 plus
Minix u22x-j max
Is this correct? What's the difference between them and is there any recommendation for the one best option?
UGOOS AM6B plus = WiFi6, Metal case better cooling, smaller footprint
UGOOS AM6 plus = WiFi5, Metal case better cooling, smaller footprint
Minix u22x-j max = WiFi5, Plastic case
the AM6B Plus can be had on Aliexpress for $160 shipped direct from Ugoos
kazuma
Post by kazuma » Wed Jun 05, 2024 3:36 pm
RESET_9999 how is your experience going with the ugoos? please inform us if you find new advantages/disadvantages. because you are most advanced user of the world of this box :D
Post by RESET_9999 » Wed Jun 05, 2024 3:55 pm
I updated the playback device spreadsheet just a few days ago, check it out
ArArdin
Post by ArArdin » Fri Jun 07, 2024 8:07 am
RESET_9999 wrote: Wed Jun 05, 2024 3:55 pm I updated the playback device spreadsheet just a few days ago, check it out
In the dual-track dual-layer support column, I noticed mkv being mentioned. Is DTDL possible in matroska nowadays?
Post by RESET_9999 » Fri Jun 07, 2024 11:03 am
It's supported when the 2nd layer has the dv flag (sidedata) and AFAIK, the only way to get that is by muxing a DT MP4.
ArArdin
Post by ArArdin » Fri Jun 07, 2024 1:51 pm
RESET_9999 wrote: Fri Jun 07, 2024 11:03 am It's supported when the 2nd layer has the dv flag (sidedata) and AFAIK, the only way to get that is by muxing a DT MP4.
Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?
Post by RESET_9999 » Fri Jun 07, 2024 2:07 pm
ArArdin wrote: Fri Jun 07, 2024 1:51 pm Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?
1- mux a DT-DL MP4 in mkvtoolnix
2- mux raw hevc layers in mkvtoolnix but this produces a dvhe.07.03 file instead of dvhe.07.06
General
Complete name                            : D:\FEL TEST DT DL P7 CMV4.0 4000nits V3.mkv
File size                                : 25.3 MiB
Duration                                 : 1 min 0 s
Overall bit rate                         : 3 527 kb/s
Frame rate                               : 23.976 FPS
Writing application                      : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 3 165 kb/s
Bits/(Pixel*Frame)                       : 0.016
Stream size                              : 22.7 MiB (90%)
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 293 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.006
Stream size                              : 2.10 MiB (8%)
Complete name                            : D:\00000.track_4113.mkv
File size                                : 381 MiB
Overall bit rate                         : 52.8 Mb/s
Video #1
Bit rate                                 : 52.7 Mb/s
Bits/(Pixel*Frame)                       : 0.265
Stream size                              : 381 MiB (100%)
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 694 cd/m2
Maximum Frame-Average Light Level        : 61 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 69.3 kb/s
Bits/(Pixel*Frame)                       : 0.001
Stream size                              : 512 KiB (0%)
ArArdin
Post by ArArdin » Sat Jun 08, 2024 11:54 am
RESET_9999 wrote: Fri Jun 07, 2024 2:07 pm1- mux a DT-DL MP4 in mkvtoolnix
Thanks, RESET. And sorry to get back on this but I had a go on both and not sure what to think here.
When importing separate BL and EL+RPU in MTX, MediaInfo indeed shows "Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03" on resulting mkv.
The above elementary tracks I extracted from a dtdl mp4, which I too - directly - imported in MTX. Weird thing here is that MediaInfo doesn't mention Dolby Vision anywhere on the mkv result.
Don't know what's happening here; do I have to set something manually in MTX GUI on DTDL mp4 import?
[EDIT] My apologies, never mind. I had a flawed mp4 source that was created with ffmpeg.
Did it with a dtdl mp4 created with mp4muxer, things are now peachy
kazuma
Post by kazuma » Sat Jun 08, 2024 4:40 pm
reset_9999 what is not working right with your gigabit-port of the ugoos? is that on alle devices of am6b? or just some?
Post by RESET_9999 » Sat Jun 08, 2024 5:34 pm
don't worry about it if you don't have a 10gbps network/hardware.
I have two Ugoos devices and they both behave the same.
kazuma
Post by kazuma » Sat Jun 08, 2024 8:26 pm
RESET_9999 wrote: Sat Jun 08, 2024 5:34 pm don't worry about it if you don't have a 10gbps network/hardware.
what? do you have a 10gbit internet line in your house :D
Post by RESET_9999 » Sat Jun 08, 2024 9:04 pm
I have a 3gbps plan but my internet speed is irrelevant. A 10gbps local network can be very useful without fast internet.
chronomac
Post by chronomac » Tue Jun 11, 2024 11:00 pm
Anyone know if Dead Reckoning has raised brightness levels like the rest of the M:I series? I didn't see it in the DV Google Sheet but wanted to double-check.
