Ok, thanks. I'll wait for a bit and hopefully it will be supported soon.texwatson wrote: Mon Jun 03, 2024 12:36 amIt's been tried. No Coreelec yet and no DV P7.MartyMcNuts wrote: Sun Jun 02, 2024 1:11 am Has anyone tried the AM8 Pro with the Amlogic S928X-J soc? Does this play DV P7 MEL/FEL mkv files via NAS streaming? Is it possible to dual boot and use CoreElec or LibreElec?
Mrmorrison
Hi everyone.
I have a TV that does not support LED TV. Nits less than 1000.
If I buy Ugoos, am I right? Or would LLDV be broken in my case?
Second question:
My TV is Android and with Kodi I can play all DV profiles up to 7 MEL. I would only use Ugoos for 7 Fel.
But if for example I have a dv 8 film, should I always prefer the internal app on the TV or can I choose Ugoos?
Second question:
sofakng wrote: Thu May 30, 2024 8:12 pm If I understand correctly, the three best devices are the following:
UGOOS AM6B plus
UGOOS AM6 plus
Minix u22x-j max
Is this correct? What's the difference between them and is there any recommendation for the one best option?
UGOOS AM6B plus = WiFi6, Metal case better cooling, smaller footprint
UGOOS AM6 plus = WiFi5, Metal case better cooling, smaller footprint
Minix u22x-j max = WiFi5, Plastic case
the AM6B Plus can be had on Aliexpress for $160 shipped direct from Ugoos
RESET_9999 how is your experience going with the ugoos? please inform us if you find new advantages/disadvantages. because you are most advanced user of the world of this box
I updated the playback device spreadsheet just a few days ago, check it out
In the dual-track dual-layer support column, I noticed mkv being mentioned. Is DTDL possible in matroska nowadays?RESET_9999 wrote: Wed Jun 05, 2024 3:55 pm I updated the playback device spreadsheet just a few days ago, check it out
It's supported when the 2nd layer has the dv flag (sidedata) and AFAIK, the only way to get that is by muxing a DT MP4.
Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?RESET_9999 wrote: Fri Jun 07, 2024 11:03 am It's supported when the 2nd layer has the dv flag (sidedata) and AFAIK, the only way to get that is by muxing a DT MP4.
ArArdin wrote: Fri Jun 07, 2024 1:51 pm Is there a guide somewhere on how to create such DTDL mkv when I have a DTDL MP4, or even already separate BL and EL+RPU? Can this be directly done in MKVToolNix?
1- mux a DT-DL MP4 in mkvtoolnix
2- mux raw hevc layers in mkvtoolnix but this produces a dvhe.07.03 file instead of dvhe.07.06
General
Complete name : D:\FEL TEST DT DL P7 CMV4.0 4000nits V3.mkv
Format : Matroska
Format version : Version 4
File size : 25.3 MiB
Duration : 1 min 0 s
Overall bit rate : 3 527 kb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 3 165 kb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.016
Stream size : 22.7 MiB (90%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate : 293 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.006
Stream size : 2.10 MiB (8%)
Default : Yes
Forced : No
Complete name : D:\00000.track_4113.mkv
Format : Matroska
File size : 381 MiB
Overall bit rate : 52.8 Mb/s
Video #1
Format : HEVC
Bit rate : 52.7 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.265
Stream size : 381 MiB (100%)
Default : Yes
Forced : No
Mastering display color primaries : BT.2020
Maximum Content Light Level : 694 cd/m2
Maximum Frame-Average Light Level : 61 cd/m2
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate : 69.3 kb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.001
Stream size : 512 KiB (0%)
Default : Yes
Forced : No
Thanks, RESET. And sorry to get back on this but I had a go on both and not sure what to think here.RESET_9999 wrote: Fri Jun 07, 2024 2:07 pm1- mux a DT-DL MP4 in mkvtoolnix
When importing separate BL and EL+RPU in MTX, MediaInfo indeed shows "Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.03" on resulting mkv.
The above elementary tracks I extracted from a dtdl mp4, which I too - directly - imported in MTX. Weird thing here is that MediaInfo doesn't mention Dolby Vision anywhere on the mkv result.
Don't know what's happening here; do I have to set something manually in MTX GUI on DTDL mp4 import?
[EDIT] My apologies, never mind. I had a flawed mp4 source that was created with ffmpeg.
Did it with a dtdl mp4 created with mp4muxer, things are now peachy
reset_9999 what is not working right with your gigabit-port of the ugoos? is that on alle devices of am6b? or just some?
don't worry about it if you don't have a 10gbps network/hardware.
I have two Ugoos devices and they both behave the same.
what? do you have a 10gbit internet line in your houseRESET_9999 wrote: Sat Jun 08, 2024 5:34 pm don't worry about it if you don't have a 10gbps network/hardware.
I have a 3gbps plan but my internet speed is irrelevant. A 10gbps local network can be very useful without fast internet.
Anyone know if Dead Reckoning has raised brightness levels like the rest of the M:I series? I didn't see it in the DV Google Sheet but wanted to double-check.
