Dune (2021) Submitted
amanofcharacter
Post by amanofcharacter » Tue Jun 04, 2024 5:52 am
I got the "volume key is unknown - disc can't be encrypted" error for Dune (2021).
The TGX generated has the name "MKB20_v76_Dune_94E9.tgz".
I see that at least one other user has submitted this here:
viewtopic.php?f=12&t=34006&p=153893#p153893
I was originally getting the issue "Automatic HK downloading is disabled or failed" as well, but appear to have gotten around using the VPN and/or disabling firewall method. I no longer get the HK error.
I also downloaded the latest keydb.cfg manually using FindVUK 1.75. Anyway, the disc still will not open, so I've submitted it.
Re: Dune (2021) Submitted
Post by Billycar11 » Tue Jun 04, 2024 9:23 am
sorry to break it to you but your hk issue is not solved your dump is name the same as the one you linked so it is supported since at least may 1ST
try different end points for your vpn
