Ultimate UHD Drives Flashing Guide Updated 2024
EDIT: Sometimes I drive myself nuts. I flashed the drive some time ago and did not realize I used the "MK" bin. That was the issue. Once I re-flashed using the non "MK" bin, everything was back to normal. Ignore the stuff below...lol
___________________
First post and I registered here for this. Long time read, first time poster. Appreciate all the hard work that has gone into this guide. I used it myself several years ago when I got my drive.
So I recently discovered an issue that was not there before and I am curious if anyone else is seeing it. I have an LG BD-RE WH16NS60. Flashed to 1.02. It works flawlessly in MakeMKV, and it used to work in DVD Fab as well. Now DVD Fab tells me I have a UHD friendly drive, but need to downgrade the FW. Again, it is worth noting that it rips just fine in MakeMKV. Anyone else having issues recently with DVD Fab?
OS device name: H:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: (hidden by me)
Highest AACS version: 76
Firmware version: 1.02
___________________
OS device name: H:
Revision: 1.02
I'm pretty certain that NS60 1.02-MK has never worked with DVDFab as it doesn't like MK firmware. NS60 1.00 firmware does as it is an original firmware (not an MK one). If you want to use this drive with DVDFab, flash it to WH16NS60 1.00.MrDystopian wrote: ↑Fri May 10, 2024 12:07 amFirst post and I registered here for this. Long time read, first time poster. Appreciate all the hard work that has gone into this guide. I used it myself several years ago when I got my drive.
OS device name: H:
Revision: 1.02
I feel like a new post needs to be made for 2024 with clearer instructions? Maybe it's just information overload for me and being led to different threads and posts that lead to another set of confusions.
Anyway, I have a LG - BP60NB10
What all do I need? From the very first post, it seems I need:
1. The firmware (I downloaded "The all you need firmware pack" - file 'HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin')
2. The flasher - which one is it? GUI SDF tool or LG flasher + DE firmware ?
thx for clearing my head.
It says use sdf GUI and to go directly to the fw you mention does not get simpler than that.digitaltrance wrote: ↑Thu May 16, 2024 2:58 pmI feel like a new post needs to be made for 2024 with clearer instructions? Maybe it's just information overload for me and being led to different threads and posts that lead to another set of confusions.
LG flashing has not changed since 2020-2021 if it were to get updated it would only get more complicated
Billycar11 wrote: ↑Thu May 16, 2024 6:29 pmIt says use sdf GUI and to go directly to the fw you mention does not get simpler than that.digitaltrance wrote: ↑Thu May 16, 2024 2:58 pmI feel like a new post needs to be made for 2024 with clearer instructions? Maybe it's just information overload for me and being led to different threads and posts that lead to another set of confusions.
Clear as mud even though 155 pages into the thread people are still asking questions lol. Just a joke and I do appreciate your efforts.
What is this 1.03-MK.bin file vs the other HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin file?
I noticed the GIF image shows that you need to WRITE first, then RECOVER?
the gif is irrelevant for you you have a BP60 not 50 you dont do the recover stepsdigitaltrance wrote: ↑Fri May 17, 2024 3:15 amBillycar11 wrote: ↑Thu May 16, 2024 6:29 pmIt says use sdf GUI and to go directly to the fw you mention does not get simpler than that.digitaltrance wrote: ↑Thu May 16, 2024 2:58 pmI feel like a new post needs to be made for 2024 with clearer instructions? Maybe it's just information overload for me and being led to different threads and posts that lead to another set of confusions.
What is this this 1.03-MK.bin file vs the other HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin file?
you are making this more complicated all you have to do is select the fw for your drive in the first post in sdf gui and your done
Ok thanks Billy. Will advise if I have any issues, thanks again.Billycar11 wrote: ↑Fri May 17, 2024 3:18 amthe gif is irrelevant for you you have a BP60 not 50 you dont do the recover stepsdigitaltrance wrote: ↑Fri May 17, 2024 3:15 amBillycar11 wrote: ↑Thu May 16, 2024 6:29 pm
I recently purchased an OWC Mercury Pro 16X Blu-ray drive from Amazon and it's not working to when trying to read 4K ultra HD movies. I've flashed the drive using this firmware (HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin) but it's still not decrypting the 4K movies. Regular 1080p blu ray movies work fine but not the 4K. Any suggestions on how to get this to work? See below for the drive specs based on the info from Amazon.
Mercury Pro Specifications:
OWC Part Number
• MR3UBDRW16
Software Requirements
• OS
o OS X 10.6 or later
o Windows XP or later
• Driver
o Driver not required
Hardware Requirements
• Minimum
o Mac or PC featuring USB 2.0 interface
• Recommended (Best Performance)
o Mac or PC featuring USB 3.0 interface
Interface (Chipset)
• (1) USB 3.0 (ASMedia ASM1053E)
Standard Mechanism
• LG WH16NS40 16X 5.25" Internal Blu-ray Disc Rewriter
Power Supply
• Internal UL-listed, universal auto-switching
• AC input: 100 ∼ 240V, 50-60Hz
• DC output: 12V, 3A
Dimensions
• Height: 2.0 in (5.2 cm)
• Width: 6.5 in (16.6cm)
• Length: 8.3 in (21.0 cm)
Weight
• With Drive: 5.7 lbs. (2.6 kg)
• Without Drive: 4.0 lbs. (1.8 kg)
LG Super Multi Blue Specs:
Super Multi Blue Internal SATA 16x Blu-ray Disc Rewriter
Form Factor: 5.25" Desktop
Interface: SATA
Loading Mechanism: Tray
Buffer Memory: 4MB
OWC Part Number
• MR3UBDRW16
• OS
• Driver
• Minimum
Interface (Chipset)
Standard Mechanism
Power Supply
Dimensions
Weight
Interface: SATA
Buffer Memory: 4MB
I doubt it has anything to do with the enclosure. Try showing us the MakeMKV log so we can see the relevant info.d1987 wrote: ↑Sat Jun 01, 2024 4:43 pmHi,
OWC Part Number
• MR3UBDRW16
• OS
• Driver
• Minimum
Interface (Chipset)
Standard Mechanism
Power Supply
Dimensions
Weight
Interface: SATA
Buffer Memory: 4MB
Not sure if this is what you're referring to.
Debug log started at Sun Jun 02 00:46:38 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) started
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF v097: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLZNAU84300
001011:0000 Using LibreDrive mode (v06.3 id=7FA2657C7667)
DEBUG: Code 2147483648 at vtE<(>?]*E!<z7r!:121265499
DEBUG: Code 0 at vtE<(>?]*E!<z7r!:29399956
Yeah but where's the rest of it? If you are getting errors when ripping UHD, they will appear in the log.d1987 wrote: ↑Sun Jun 02, 2024 12:47 amNot sure if this is what you're referring to.
I enabled the debug log. I'm not familiar with this program but let me know if this is what you're looking for.
Debug log started at Sun Jun 02 03:29:31 2024 , written by MakeMKV v1.17.7 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\John/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at vtE<(>?]*E!<z7r!:29399956
003332:0000 Saved AACS dump file as file://C:\Users\John/.MakeMKV/MKB20_v61_Dunkirk_DBF5.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721
001003:0020 DEBUG: Code 0 at *?fa{/h[G&00(#,E:213131341
Application exited at Sun Jun 02 03:30:03 2024
Email MKB20_v61_Dunkirk_DBF5.tgz to svq@makemkv.com & retry the disc periodically over the next week, or 2. When the dump has been processed & the key is available, MakeMKV should automatically update & the disc will decrypt/ rip.d1987 wrote: ↑Sun Jun 02, 2024 3:32 amI enabled the debug log. I'm not familiar with this program but let me know if this is what you're looking for.
Some additional light reading to familiarize yourself w/ the world of MakeMKV re: UHD discs...
UHD FAQ 1st post, mostly
Fixing Volume Key is Unknown 1st post, mostly
Thank you. I'll send the log to the email provided and do some reading.
Thanks for the assistance. My firewall was blocking the HK from being downloaded. The drive is decrypting the UHD file now.
