Asus BW-16D1X-U
RedLine
Re: Asus BW-16D1X-U
Post by RedLine » Sat Jun 01, 2024 2:25 pm
First and foremost,
I want to thank everyone that helped me. The amount of information in these forums and the quick responses to my questions was incredible!
TL:DR: I purchased an ASUS BW-16D1X-U from Amazon, used the GUI "SDFtool Flasher" to backup my current firmware and flashed to "DE_ASUS_BW-16D1HT_3.10_MK". The drive is now able to read UHD 4K disks!
My Pioneer BDR-XD07UHD drive was having read issues on a few discs. One suggestion was to flash to the latest firmware version. It didn't even cross my mind to check the MakeMKV forums, so after the flash, it no longer supports MakeMKV and UHD discs. With some help from a few forum users and all the great posts (like this one), I purchased an ASUS BW-16D1X-U from Amazon. I used the GUI "SDFtool Flasher (v1.3.5)" to backup my current firmware and flashed the drive to "DE_ASUS_BW-16D1HT_3.10_MK".
For testing, I used Monster Hunters (2020) 4K Ultra HD + BLU-RAY + Digital discs. Before flashing the drive, I verified the UHD 4K disc could not be read. I ripped the Blu-Ray disc and it took just under 18 minutes. I flashed the drive and verified the 4K UHD disc could be read. I then ripped the Blu-Ray disc a second time. The rip time remained roughly the same - just under 18 minutes. I ripped the 4K UHD disc without any issues.
UPDATE | EDIT
Per Coopervid's answer to one of my questions, I flashed the drive with the "HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin" firmware. The drive was able to read the Monster Hunter 4K / UHD disc. I ripped the Monster Hunters Blu-Ray disc a third time and the rip completed 1 minute faster.
MT1956 Platform (flagged - green checkmark)
Encrypted Firmware (flagged - green checkmark)
Pre-Flash Drive Information
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: xxxxxxxxxx
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 76
Post Flash Drive Information
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Firmware version: 3.10
Update| Edit
Drive Information After 1.03 Flash
OS device name: G:
Product: BD-RE WH16NS60
Revision: 1.03
Firmware date: 2120-05-08 10:10
Firmware version: 1.03
I do have two questions.
  • In this post, someone mentioned the following. After flashing this drive, it can no longer write discs. Is that correct?
  • In this post, people used two different firmware to flash this drive. "DE_ASUS_BW-16D1HT_3.10_MK" which comes in the Marty's firmware pack and "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" or the 1.03 version that you download from GetHub. Which is best or does it even matter?
Again, thanks everyone!!!!
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Jun 01, 2024 6:41 pm
1) AFAIK this doesn't affect burning but you should burn with you Pioneer anyway as this is the better burner (even it doesn't read UHDs anymore after you f..ed it up).
2) The official firmware from WH16NS60 doesn't have the sleep bug and it reads 3-layer discs better than the friendly ASUS firmware.
RedLine
Re: Asus BW-16D1X-U
Post by RedLine » Sat Jun 01, 2024 8:55 pm
Coopervid wrote: Sat Jun 01, 2024 6:41 pm 1) AFAIK this doesn't affect burning but you should burn with you Pioneer anyway as this is the better burner (even it doesn't read UHDs anymore after you f..ed it up).
Coopervid,
Thanks for the information!!!
amateurhour999
Re: Asus BW-16D1X-U
Post by amateurhour999 » Tue Jun 04, 2024 10:20 pm
Hi clever people, I don't know if anyone will even see this, and please be even gentler with me, I am a painfully novice. I seek your kind assistance please.
I have the exact same Asus 16D1X-U external drive
I want to be able to rip blu ray discs
I've downloaded MKV, I've downloaded the SDF flasher and the 'All you need...' firmware pack
I also read somewhere I need Java runtime environment, so I downloaded that too
In the SDF flasher, when I try to select the firmware from my recent downloads it is not visible
I then saved the individual firmware packs as separate notepad documents to my desktop
This made them visible on SDF
But none of them do anything when I run them, all have same same error: "Command produce error code 0xfffffffff"
Can anyone point me in the right direction please?
Re: Asus BW-16D1X-U
Post by Coopervid » Wed Jun 05, 2024 7:52 am
amateurhour999 wrote: Tue Jun 04, 2024 10:20 pm Hi clever people, I don't know if anyone will even see this, and please be even gentler with me, I am a painfully novice. I seek your kind assistance please.
Post your Makemkv information for your drive. It can be a LG type or a Pioneer type. We have to see to help you.
amateurhour999
Re: Asus BW-16D1X-U
Post by amateurhour999 » Wed Jun 05, 2024 8:42 pm
Thank you for responding!
amateurhour999
Re: Asus BW-16D1X-U
Post by amateurhour999 » Thu Jun 06, 2024 9:45 pm
I sent the specs on the first message but the board wont let me attach a screenshot so here goes:
Drive information
OS device name: G:
current profile: DVD rom
Manufacturer: ASUS
Product BW-16D1X-U
Revision: E113
Serial number: CHDL....
Firmware update: 2020-07-21
Bus encryption: 1B
Libre drive info
Status: possible, not yet enable
Firmware version: ID76
TMul440
Re: Asus BW-16D1X-U
Post by TMul440 » Wed Aug 07, 2024 12:22 am
Hello. New member trying to see if my drive is flashable. When I put in a UHD it spins up yet eventually says so disc inserted. Any help would be appreciated. Thanks, Tom
Re: Asus BW-16D1X-U
Post by Woodstock » Wed Aug 07, 2024 12:39 am
Your link is unreadable.
What is your drive's information (quoted text is best)?
TMul440
Re: Asus BW-16D1X-U
Post by TMul440 » Wed Aug 07, 2024 12:53 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: QEDL124570WL
Firmware date: 2018-01-15
Highest AACS version: 66
Drive platform: RS8600
Firmware version: E102/ID76
Here you go
Re: Asus BW-16D1X-U
Post by Billycar11 » Wed Aug 07, 2024 1:27 am
TMul440 wrote: Wed Aug 07, 2024 12:53 am Drive Information
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Here you go
email me if you want it to read UHD i have a flasher for it.
see below
TMul440
Re: Asus BW-16D1X-U
Post by TMul440 » Wed Aug 07, 2024 1:30 am
Thank You. Sending you an email now.
Re: Asus BW-16D1X-U
Post by Coopervid » Wed Aug 07, 2024 10:52 am
amateurhour999 wrote: Thu Jun 06, 2024 9:45 pm I sent the specs on the first message but the board wont let me attach a screenshot so here goes:
Drive information
OS device name: G:
Manufacturer: ASUS
Product BW-16D1X-U
Revision: E113
Bus encryption: 1B
Libre drive info
PM sent.
Re: Asus BW-16D1X-U
Post by Coopervid » Sun Aug 11, 2024 10:10 pm
Drive information
OS device name: G:
Manufacturer: ASUS
Product BW-16D1X-U
Revision: E113
Bus encryption: 1B
Libre drive info
Your PM is about to expire.
neotoma
Re: Asus BW-16D1X-U
Post by neotoma » Wed Oct 30, 2024 2:58 pm
I am running into the same issue as the person above.
Screenshot 2024-10-30 075653.png (131.04 KiB) Viewed 31701 times
