ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
rye-amts wrote: Wed May 01, 2024 10:26 pm
Billycar11 wrote: Wed May 01, 2024 9:55 pm on mac your out of luck
if you have access to a pc email me that drive info and i can sell you an automated flasher for $25
I suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?
very simple but not sure if you want to do that
Malloc
Post by Malloc »
I've recently purchased an ASUS SBW-06D2X-U external blu ray player/fingerprint magnet, can I ask the procedure to make it LibreDrive enabled?.
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.11
Serial number: [redacted]
Firmware date: 2023-04-20
Firmware version: ID22
Malloc wrote: Thu May 30, 2024 2:59 am I've recently purchased an ASUS SBW-06D2X-U external blu ray player/fingerprint magnet, can I ask the procedure to make it LibreDrive enabled?.
Manufacturer: ASUS
Revision: 1.11
email me for the flash kit see below
mentolathum
Post by mentolathum »
Hello, I just bought that same unit, could someone please give me the instructions to do the flashing?
Jam1668
Post by Jam1668 »
I also have this drive however this is what it shows on makemkv
Manufacturer: ASUS
Revision: D601
Highest AACS version: 65
ricurreli96
Post by ricurreli96 »
Coopervid wrote: Wed Apr 03, 2024 9:42 pm This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Hi, i also have a ASUS SBW-06D2X-U drive and i really want also the procedure to make it LibreDrive enabled with UHDs, please send me the instructions!
Manufacturer: ASUS
Revision: 1.10
Firmware date: 2017-04-18
Highest AACS version: 66
Read your PM.
ricurreli96 wrote: Wed Jul 31, 2024 1:02 pm
Manufacturer: ASUS
Revision: 1.10
PM sent
ricurreli96
Coopervid wrote: Wed Jul 31, 2024 10:51 pm
Manufacturer: ASUS
Revision: 1.10
PM sent
Thank you very much, it worked!
ricurreli96
ricurreli96 wrote: Thu Aug 01, 2024 12:10 am
Manufacturer: ASUS
Revision: 1.10
PM sent
Hi again, i have a question:
how is it possible that the drive is now capable of read 4k Ultra HD disk?
should be physically impossible!
ricurreli96 wrote: Thu Aug 01, 2024 11:06 pm
PM sent
The hardware was always capable. Your original firmware was just "crippled".
Your PM will expire tomorrow.
centrafl
Post by centrafl »
Would I be able to get the instructions as well? Here's my drive information:
OS device name: E:
Manufacturer: ASUS
Revision: D501
Highest AACS version: 68
centrafl wrote: Thu Aug 08, 2024 8:05 am Would I be able to get the instructions as well? Here's my drive information:
OS device name: E:
Manufacturer: ASUS
Revision: D501
The drive platform information is missing.
centrafl
Post by centrafl »
Libre drive information doesn't pull up for that drive for some reason, but for other drives it does. Does that mean its not supported?
