Is the decrypt key available for MKB20_v77_THE_CREATOR_89B8?
swframe
#1 Post by swframe » Mon May 27, 2024 5:16 am
(Sorry I'm new. Please let me know if there is a better way to ask this question.)
I'm using makemkv version 1.17.7 win x64 release.
It is UHD disk info:
OS device name: M:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU10
Firmware date: 2117-05-30 17:28
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 0.BU10O
Disc Information
Label: THE_CREATOR
Timestamp: 2023-10-27 10:17:01
Protection: AACS2.0/C v77
Data capacity: 60.22 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Re: Is the decrypt key available for MKB20_v77_THE_CREATOR_89B8?
#2 Post by Woodstock » Mon May 27, 2024 3:11 pm
Did you submit the generated file to have a key created?
Do you have download of keys enabled, and does the log show that a connection can be made?
These are more important questions.
#3 Post by dcoke22 » Mon May 27, 2024 4:03 pm
I didn't see that dump mentioned in an of the other The Creator (2023) threads.
The Creator UK
The Creator dump sent (1DDC)
Submitted dump file for The Creator
See the hashed keys section of the UHD FAQ. Email your dump to svq@makemkv.com.
swframe
#4 Post by swframe » Mon May 27, 2024 4:06 pm
