BD-RW BDR-XD07U | Status: Possible, not yet enabled
RedLine
#1 Post by RedLine » Sun May 26, 2024 11:42 pm
@Mike Admin
Mike,
I have a Pioneer BDR-XD07UHD drive with firmware ID05. When I tried to open the 4K UHD "Monster Hunters" disc, I receive the following error message. "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive".
Also, the LibreDrive Status is "Possible, not yet enabled". Is there plans to enable it for my drive?
Thanks.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.05
Serial number: AHDL010462UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: MONSTER_HUNTER_2020
Timestamp: 2020-12-22 08:44:17
Protection: AACS2.0/C v76
Data capacity: 48.47 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Re: BD-RW BDR-XD07U | Status: Possible, not yet enabled
#2 Post by MartyMcNuts » Mon May 27, 2024 12:02 am
RedLine wrote: Sun May 26, 2024 11:42 pm @Mike Admin
Mike,
Thanks.
OS device name: H:
Revision: 1.05
Disc Information
Number of layers: 2
Currently cannot be done as the firmware is too new. Any firmware from 12/22 is the issue as Pioneer has done something to stop UHD from working.
It's a waiting game and has been a year and a half so far. It may happen. It may never happen. We don't know yet ..
Your best bet is to return the drive if possible and if you want a pioneer, get one from a seller in your region.
RedLine
#3 Post by RedLine » Mon May 27, 2024 3:22 am
Thanks for the info!
