Longshot with Pioneer BDR-209D
nw86281
Post by nw86281 » Tue May 07, 2024 6:06 pm
This might be a bit of a long shot, but I have a Pioneer BDR-209D made in December 2013. Below is the info from MakeMKV. I have a feeling this drive may be too old to flash to be able to read 4K discs. Can anyone confirm if it is too old or if it is possible to flash it and enable it to read UHD discs?
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: MLDL010336WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 27
Drive platform: RS8600
Firmware version: 1.51/ID61
Re: Longshot with Pioneer BDR-209D
Post by Billycar11 » Tue May 07, 2024 8:33 pm
nw86281 wrote: Tue May 07, 2024 6:06 pm This might be a bit of a long shot, but I have a Pioneer BDR-209D made in December 2013. Below is the info from MakeMKV. I have a feeling this drive may be too old to flash to be able to read 4K discs. Can anyone confirm if it is too old or if it is possible to flash it and enable it to read UHD discs?
OS device name: H:
Revision: 1.51
Email me for the flasher see below
RedCMN
Post by RedCMN » Fri May 24, 2024 9:00 pm
I'll post here instead of creating a new thread -- My ASUS drive gave up the ghost, but I have this drive in my headless Mac Pro that I retired last year:
Revision: 1.34
Serial number: QJDL160881WL
Firmware date: 2016-04-25
Highest AACS version: 81
Firmware version: 1.34/ID61
Disc Information
Disc is being loaded
Any chance this can be flashed -- and flashed on a Mac -- as I would prefer to save this Pioneer, even though I'll likely pick up a cheap LG later.
Post by Coopervid » Fri May 24, 2024 11:25 pm
RedCMN wrote: Fri May 24, 2024 9:00 pm I'll post here instead of creating a new thread -- My ASUS drive gave up the ghost, but I have this drive in my headless Mac Pro that I retired last year:
Revision: 1.34
Disc Information
If you have access to a Windows PC there is hope.
Axelbcn
Post by Axelbcn » Wed Apr 02, 2025 3:38 pm
Someone help me with this device to make it 4K compatible ?
OS device name: H:
Revision: 1.34
Serial number: .......
Post by Billycar11 » Wed Apr 02, 2025 8:12 pm
Axelbcn wrote: Wed Apr 02, 2025 3:38 pm Someone help me with this device to make it 4K compatible ?
OS device name: H:
Revision: 1.34
Sure email me
stevenrfrey
Post by stevenrfrey » Fri Aug 15, 2025 6:22 pm
I have a Pioneer BDR-209D Libre is enabled but it won't read any 4K discs
Post by Coopervid » Fri Aug 15, 2025 6:54 pm
stevenrfrey wrote: Fri Aug 15, 2025 6:22 pm I have a Pioneer BDR-209D Libre is enabled but it won't read any 4K discs
You need to post your Makemkv info as there are 2 hardware versions.
stevenrfrey
Post by stevenrfrey » Fri Aug 15, 2025 10:54 pm
OS device name: F:
Revision: 1.50
Serial number: RADL004291WL
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: 1.50/ID61
Post by Coopervid » Sat Aug 16, 2025 8:37 am
stevenrfrey wrote: Fri Aug 15, 2025 10:54 pm Drive Information
OS device name: F:
Revision: 1.50
PM sent.
stevenrfrey
Post by stevenrfrey » Sat Aug 16, 2025 7:38 pm
it says drive and firmware don't match
Post by Coopervid » Sun Aug 17, 2025 1:17 pm
stevenrfrey wrote: Sat Aug 16, 2025 7:38 pm it says drive and firmware don't match
My bad. I had sent you the version for hardware 8600 instead of 8601. You have a new PM now.
stevenrfrey
Post by stevenrfrey » Mon Aug 18, 2025 7:44 pm
Thanks I will try it and let you know I appreciate your time
epicfx37355
Post by epicfx37355 » Sat Aug 23, 2025 6:32 pm
can I jump on this as well? here is my drive info
OS device name: F:
Revision: 1.51
Serial number: NCDL030681WL
Highest AACS version: 68
Post by Coopervid » Sat Aug 23, 2025 8:07 pm
epicfx37355 wrote: Sat Aug 23, 2025 6:32 pm can I jump on this as well? here is my drive info
OS device name: F:
Revision: 1.51
PM sent.
