Pioneer BDR-209UBK work with 4K UHD discs?
Tokenfreak
Will my Pioneer BDR-209UBK be able to read 4K UHD discs or does it need to be flashed? It works fine with Blu-ray Discs but I am thinking about upgrading my collect to 4K soon and was curious if I can keep using this drive or not. Thanks!
Re: Pioneer BDR-209UBK work with 4K UHD discs?
needs to be flashed email me for an auto flasher see belowTokenfreak wrote: Wed May 22, 2024 12:15 am Will my Pioneer BDR-209UBK be able to read 4K UHD discs or does it need to be flashed? It works fine with Blu-ray Discs but I am thinking about upgrading my collect to 4K soon and was curious if I can keep using this drive or not. Thanks!
Tokenfreak
Thanks! Maybe I am good though with the way the drive is now since it has the original firmware? I guess I should buy my first 4K UHD disc and see what happens and then go from there. This is what Make MKV shows right now:Billycar11 wrote: Wed May 22, 2024 2:03 amneeds to be flashed email me for an auto flasher see belowTokenfreak wrote: Wed May 22, 2024 12:15 am Will my Pioneer BDR-209UBK be able to read 4K UHD discs or does it need to be flashed? It works fine with Blu-ray Discs but I am thinking about upgrading my collect to 4K soon and was curious if I can keep using this drive or not. Thanks!
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Serial number: NFDL003837WL
Firmware date: 2014-04-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.20/ID60
Unrestricted read speed: Yes-
Nah won't work without flashing just email me that info and I'll send you the flasher infoTokenfreak wrote: Wed May 22, 2024 1:56 pmThanks! Maybe I am good though with the way the drive is now since it has the original firmware? I guess I should buy my first 4K UHD disc and see what happens and then go from there. This is what Make MKV shows right now:Billycar11 wrote: Wed May 22, 2024 2:03 amneeds to be flashed email me for an auto flasher see belowTokenfreak wrote: Wed May 22, 2024 12:15 am Will my Pioneer BDR-209UBK be able to read 4K UHD discs or does it need to be flashed? It works fine with Blu-ray Discs but I am thinking about upgrading my collect to 4K soon and was curious if I can keep using this drive or not. Thanks!
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.20 Serial number: NFDL003837WL Firmware date: 2014-04-08 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.20/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
But feel free to try a UHD disc first to make sure
Tokenfreak
You’re right it didn’t read a UHD disc. I just sent the payment and emailed you back. Just waiting on the flasher now. Thanks!
flasher sent a few hours agoTokenfreak wrote: Sat May 25, 2024 8:27 pm You’re right it didn’t read a UHD disc. I just sent the payment and emailed you back. Just waiting on the flasher now. Thanks!
maker10
I also have this drive in a Vantac enclosure. Will this flash enable the drive to be detected by Linux Ubuntu server or just Windows?
It will work on Linux but needes to be flashed on windowsmaker10 wrote: Sun Jun 02, 2024 6:46 pm I also have this drive in a Vantac enclosure. Will this flash enable the drive to be detected by Linux Ubuntu server or just Windows?
maker10
Email request sent
John Barleycorn
Email request sent.
wrbreland
For anyone that has a flashed BDR-209UBK, does it read 3 layer UHD Blu-ray disc without issues?
Yes reads 3 layer discs fine email me if you want the flasher for it.wrbreland wrote: Wed Jun 05, 2024 3:21 pm For anyone that has a flashed BDR-209UBK, does it read 3 layer UHD Blu-ray disc without issues?
kripa1976
I have the Pioneer BDR-209UBK. Wil the flasher work for my drive as well so that it can be able to read the 4K discs?
Here's the drive information.
OS device name: K:
Revision: 1.54
Serial number: [redacted]
Firmware date: 2020-07-21
Highest AACS version: 77
Firmware version: 1.54/ID60
OS device name: K:
Revision: 1.54
Yeah email me I have the flasher you needkripa1976 wrote: Mon Oct 07, 2024 7:59 pm I have the Pioneer BDR-209UBK. Wil the flasher work for my drive as well so that it can be able to read the 4K discs?
OS device name: K:
Revision: 1.54
dmdmmatt4
Interesting. I had a 209 for ages till it died. It was a good ripper but I didn't have any uhd back then.
It died one day a year or so ago and refused to talk to me after that.
