Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Warning! All links for your UD03 fixes that I have sent will be deleted by the end of the week if not read.
Let me list the idiots who don't read their PMs:
sydcor01
jeepsey
SneakyGit
stoggi
You asked for help and didn't read your PM. Are you all retarded or why did you post for help and then you just disappear?
sydcor01
jeepsey
SneakyGit
stoggi
spucknicht
Hi coopervidCoopervid wrote: Tue May 21, 2024 8:37 pm Warning! All links for your UD03 fixes that I have sent will be deleted by the end of the week if not read.
I have got a verbatim 43890 with pioneer BDR-UD3 rev 1.11. Is there a fix for mine too?
Read your PM but it will expire soon if not read.spucknicht wrote: Thu May 23, 2024 6:33 pmHi coopervidCoopervid wrote: Tue May 21, 2024 8:37 pm Warning! All links for your UD03 fixes that I have sent will be deleted by the end of the week if not read.
spucknicht
thanks for the help Coopervid.
hatware
Hello all,
I have a Silverstone TOBO4 here, which is really a BDR-UD03-ASW. I think I lucked out with a mfr date Oct 2017 model. Is this flashable like other UD03's? Appears to have 1.00HW and 1.00FW versions.
Haven't seen much about this drive, figure I'd throw my hat in the ring.
email me your makemkv drive info section for a flasherhatware wrote: Fri May 24, 2024 10:52 pm Hello all,
nads888
hey coopervid,Coopervid wrote: Tue May 21, 2024 8:37 pm Warning! All links for your UD03 fixes that I have sent will be deleted by the end of the week if not read.
i also picked up this drive real cheap. can you shoot me a pm with details on UHD.
cheers
Raed your PM.
nads888
hey thanks for the pm, the link doesn't seem to work.
I have a lot of trouble with the generated links. Try the new one and report back.
reebot
Hi, I've got:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
can I get help with getting right firmware for enabling UHD read?
Revision: 1.14
read your PMreebot wrote: Tue Jun 04, 2024 6:19 pm Hi, I've got:
Revision: 1.14
reebot
when i open the link from PM I get "Something went wrong, access Denied"
Try the new link. Report back if it still doesn't work.reebot wrote: Wed Jun 05, 2024 2:12 amwhen i open the link from PM I get "Something went wrong, access Denied"
