Pioneer BDR-212DBK vs BDR-212V
bluray4k
Re: Pioneer BDR-212DBK vs BDR-212V
#31 Post by bluray4k » Mon May 20, 2024 4:55 pm
@Coopervid it worked! Thank you so much!
jf1756
#32 Post by jf1756 » Mon May 20, 2024 6:16 pm
@Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: xxxxxxxxxxxx
Firmware date: 2020-07-21
Highest AACS version: 78
Firmware version: ID76
#33 Post by Coopervid » Tue May 21, 2024 9:28 am
jf1756 wrote: Mon May 20, 2024 6:16 pm @Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Read your PM.
jf1756
#34 Post by jf1756 » Tue May 21, 2024 8:01 pm
@Coopervid Thanks it worked great!
mattchew
#35 Post by mattchew » Wed May 22, 2024 1:31 am
@Coopervid
Could I please get help?
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
Thank you!
#36 Post by Coopervid » Wed May 22, 2024 8:59 am
mattchew wrote: Wed May 22, 2024 1:31 am @Coopervid
Revision: 1.02
Thank you!
Read your PM.
wibbl3
#37 Post by wibbl3 » Thu Jun 06, 2024 6:15 pm
Mine arrived. I'd appreciate a PM. :)
OS device name: E:
Revision: 1.02
Serial number: -snip-
Highest AACS version: 57
Thank you
Barque
#38 Post by Barque » Mon Jun 10, 2024 2:24 am
Revision: 1.02
Serial number: -----------
Highest AACS version: 81
@Coopervid I'd greatly appreciate your help if you're willing to provide it!
vidupgrade
#39 Post by vidupgrade » Fri Jun 14, 2024 3:06 pm
@Coopervid could I please get help too?
Revision: 1.02
#40 Post by Coopervid » Fri Jun 14, 2024 9:29 pm
vidupgrade wrote: Fri Jun 14, 2024 3:06 pm @Coopervid could I please get help too?
Revision: 1.02
Check your PM
vidupgrade
#41 Post by vidupgrade » Sat Jun 15, 2024 12:44 am
Coopervid wrote: Fri Jun 14, 2024 9:29 pm
Revision: 1.02
Check your PM
Perfect! Thank you!
jcarlino
#42 Post by jcarlino » Wed Jun 19, 2024 10:54 pm
zaqqaz6917 wrote: Tue Apr 16, 2024 3:39 pm Just want to thank Cooper who helped me with updating the FW on this drive to make it a Libredrive
Big thanks
Edit to add
This drive maybe the only pioneer drive currently available off the shelf retail new to be able to enable Libredrive for UHD purposes.
It seems Amazon USA and Canada have a prime seller with plenty of stock at fw 1.02 at a very reasonable 80 bucks, even though outside of drive is is labelled Feb 2024, so don't get put off by data on outside of drive till you actually have Makemkv analyze it
Newbie here that took the plunge on trying to get a drive from Amazon and wanted to backup what zaqqaz6917 said about the drive label.
I purchased a BRD-212DBK and the drive was labeled as manufactured Jan. 2024, however when I plugged it in and opened MakeMKV it said
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-03-16
Highest AACS version: 63
Drive platform: RS8F00
Firmware version: 1.02/ID61
Now if I could just get some help getting the drive to read UHD discs :mrgreen:
zaqqaz6917
#43 Post by zaqqaz6917 » Thu Jun 20, 2024 11:39 am
@jcarlino
Pm Cooper for help
#44 Post by Coopervid » Thu Jun 20, 2024 2:51 pm
jcarlino wrote: Wed Jun 19, 2024 10:54 pm
Big thanks
Edit to add
Revision: 1.02
Check your PM.
jcarlino
#45 Post by jcarlino » Thu Jun 20, 2024 9:28 pm
Coopervid wrote: Thu Jun 20, 2024 2:51 pm
Check your PM.
Thank you! Drive now reads as an S12U and read my UHD disc, didn't try ripping though!
