Pioneer BDR-212DBK vs BDR-212V
bluray4k
Re: Pioneer BDR-212DBK vs BDR-212V
@Coopervid it worked! Thank you so much!
jf1756
@Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: xxxxxxxxxxxx
Firmware date: 2020-07-21
Highest AACS version: 78
Firmware version: ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Read your PM.jf1756 wrote: Mon May 20, 2024 6:16 pm @Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
jf1756
@Coopervid Thanks it worked great!
mattchew
@Coopervid
Could I please get help?
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
Thank you!
Revision: 1.02
Thank you!
Read your PM.mattchew wrote: Wed May 22, 2024 1:31 am @Coopervid
Revision: 1.02
Thank you!
wibbl3
Mine arrived. I'd appreciate a PM.
Thank youDrive Information
OS device name: E:
Revision: 1.02
Serial number: -snip-
Highest AACS version: 57
Barque
@Coopervid I'd greatly appreciate your help if you're willing to provide it!Drive Information
Revision: 1.02
Serial number: -----------
Highest AACS version: 81
vidupgrade
@Coopervid could I please get help too?
Revision: 1.02
Revision: 1.02
Check your PMvidupgrade wrote: Fri Jun 14, 2024 3:06 pm @Coopervid could I please get help too?
Revision: 1.02
vidupgrade
Perfect! Thank you!Coopervid wrote: Fri Jun 14, 2024 9:29 pmCheck your PMvidupgrade wrote: Fri Jun 14, 2024 3:06 pm @Coopervid could I please get help too?
Revision: 1.02
jcarlino
Newbie here that took the plunge on trying to get a drive from Amazon and wanted to backup what zaqqaz6917 said about the drive label.zaqqaz6917 wrote: Tue Apr 16, 2024 3:39 pm Just want to thank Cooper who helped me with updating the FW on this drive to make it a Libredrive
Big thanks
Edit to add
This drive maybe the only pioneer drive currently available off the shelf retail new to be able to enable Libredrive for UHD purposes.
It seems Amazon USA and Canada have a prime seller with plenty of stock at fw 1.02 at a very reasonable 80 bucks, even though outside of drive is is labelled Feb 2024, so don't get put off by data on outside of drive till you actually have Makemkv analyze it
I purchased a BRD-212DBK and the drive was labeled as manufactured Jan. 2024, however when I plugged it in and opened MakeMKV it said
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-03-16
Highest AACS version: 63
Drive platform: RS8F00
Firmware version: 1.02/ID61
No disc inserted-
zaqqaz6917
@jcarlino
Pm Cooper for help
Pm Cooper for help
Check your PM.jcarlino wrote: Wed Jun 19, 2024 10:54 pmNewbie here that took the plunge on trying to get a drive from Amazon and wanted to backup what zaqqaz6917 said about the drive label.zaqqaz6917 wrote: Tue Apr 16, 2024 3:39 pm Just want to thank Cooper who helped me with updating the FW on this drive to make it a Libredrive
Big thanks
Edit to add
Now if I could just get some help getting the drive to read UHD discsCode: Select all
Drive Information OS device name: \Device\CdRom0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.02 Serial number: [redacted] Firmware date: 2022-03-16 Bus encryption flags: 13 Highest AACS version: 63 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.02/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted![]()
jcarlino
Thank you! Drive now reads as an S12U and read my UHD disc, didn't try ripping though!
