Pioneer BDR-212DBK vs BDR-212V
bluray4k
Re: Pioneer BDR-212DBK vs BDR-212V
Post by bluray4k »
@Coopervid it worked! Thank you so much!
jf1756
Post by jf1756 »
@Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: xxxxxxxxxxxx
Firmware date: 2020-07-21
Highest AACS version: 78
Firmware version: ID76
jf1756 wrote: Mon May 20, 2024 6:16 pm @Coopervid Could you please also help me with this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Read your PM.
jf1756
Post by jf1756 »
@Coopervid Thanks it worked great!
mattchew
Post by mattchew »
@Coopervid
Could I please get help?
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
Thank you!
mattchew wrote: Wed May 22, 2024 1:31 am @Coopervid
Revision: 1.02
Thank you!
Read your PM.
wibbl3
Post by wibbl3 »
Mine arrived. I'd appreciate a PM. :)
OS device name: E:
Revision: 1.02
Serial number: -snip-
Highest AACS version: 57
Thank you
Barque
Post by Barque »
Revision: 1.02
Serial number: -----------
Highest AACS version: 81
@Coopervid I'd greatly appreciate your help if you're willing to provide it!
vidupgrade
Post by vidupgrade »
@Coopervid could I please get help too?
Revision: 1.02
vidupgrade wrote: Fri Jun 14, 2024 3:06 pm @Coopervid could I please get help too?
Revision: 1.02
Check your PM
vidupgrade
Coopervid wrote: Fri Jun 14, 2024 9:29 pm
Revision: 1.02
Check your PM
Perfect! Thank you!
jcarlino
Post by jcarlino »
zaqqaz6917 wrote: Tue Apr 16, 2024 3:39 pm Just want to thank Cooper who helped me with updating the FW on this drive to make it a Libredrive
Big thanks
Edit to add
This drive maybe the only pioneer drive currently available off the shelf retail new to be able to enable Libredrive for UHD purposes.
It seems Amazon USA and Canada have a prime seller with plenty of stock at fw 1.02 at a very reasonable 80 bucks, even though outside of drive is is labelled Feb 2024, so don't get put off by data on outside of drive till you actually have Makemkv analyze it
Newbie here that took the plunge on trying to get a drive from Amazon and wanted to backup what zaqqaz6917 said about the drive label.
I purchased a BRD-212DBK and the drive was labeled as manufactured Jan. 2024, however when I plugged it in and opened MakeMKV it said
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-03-16
Highest AACS version: 63
Drive platform: RS8F00
Firmware version: 1.02/ID61
Now if I could just get some help getting the drive to read UHD discs :mrgreen:
zaqqaz6917
Post by zaqqaz6917 »
@jcarlino
Pm Cooper for help
jcarlino wrote: Wed Jun 19, 2024 10:54 pm
Big thanks
Edit to add
Revision: 1.02
Check your PM.
jcarlino
Post by jcarlino »
Coopervid wrote: Thu Jun 20, 2024 2:51 pm
Check your PM.
Thank you! Drive now reads as an S12U and read my UHD disc, didn't try ripping though!
