WH14NS40 Compatibility with UHD
Kreeze
#1 Post by Kreeze » Tue Apr 06, 2021 11:19 pm
Hi, noob here. I purchased a WH14NS40 (https://www.amazon.com/gp/product/B007VPGL5U) and used MakeMKV to rip a whole bunch of DVDs and standard Blu-Ray discs for my personal emby server. I did not know 4k Blu-Ray discs existed until after I purchased the drive and I am interested in buying some movies in that format. Is it possible for me to rip 4k UHD discs using this specific drive? The guides made me very wary of trying to flash firmware without checking thoroughly. I have attached a screenshot of MakeMKV with drive information if that helps. Thanks
Re: WH14NS40 Compatibility with UHD
#2 Post by MartyMcNuts » Wed Apr 07, 2021 3:02 am
Kreeze wrote: Tue Apr 06, 2021 11:19 pm Hi, noob here. I purchased a WH14NS40 (https://www.amazon.com/gp/product/B007VPGL5U) and used MakeMKV to rip a whole bunch of DVDs and standard Blu-Ray discs for my personal emby server. I did not know 4k Blu-Ray discs existed until after I purchased the drive and I am interested in buying some movies in that format. Is it possible for me to rip 4k UHD discs using this specific drive? The guides made me very wary of trying to flash firmware without checking thoroughly. I have attached a screenshot of MakeMKV with drive information if that helps. Thanks
Yep, that drive is flashable to enable UHD ripping. Your drive does currently have encrypted firmware on it though. The recommended firmware for that model is WH16NS60 1.02-MK.
If you are not sure about doing it yourself, you can get yourself a 'Single Drive Flasher' (choose the WH16NS60_1.02-MK one) from my new website (link in my signature) which will automatically perform the required checks for you before flashing the drive. All you need to do is select your drive in the dropdownbox and click "START".
Kreeze
#3 Post by Kreeze » Thu Apr 08, 2021 3:42 am
Thank you! I have successfully patched my drive.
Maysun91
#4 Post by Maysun91 » Sat May 18, 2024 8:17 pm
Chiming in from 3 years in the future, thank you so much for this! Your installer worked like magic for me. Happy to support the work everyone does over here. Just getting into the scene but its been relatively painless with everyone's helpfulness!
