Cryptic post issue.
abuttino
Cryptic post issue.
Post by abuttino » Sat May 18, 2024 5:16 pm
The "Recommended drives" and firmware to flash them with is very convoluted and doesn't say which utility to flash and what version to flash with absolute definitive. It says it on several different paragraphs and bullet points.
The drive in question is an BP60NB10.
Thank you for your help.
Tony B.
Re: Cryptic post issue.
Post by MartyMcNuts » Sat May 18, 2024 11:43 pm
abuttino wrote: Sat May 18, 2024 5:16 pm The "Recommended drives" and firmware to flash them with is very convoluted and doesn't say which utility to flash and what version to flash with absolute definitive. It says it on several different paragraphs and bullet points.
Tony B.
It's not hard. If the drive is new, it's most likely a BP60NB10 SVC: NB12. Simply use SDFTool Flasher and flash BP60NB10 NB12 1.02-MK firmware and you are good to go!
