ASUS BW-16D1X-U - Flashable?
ggrussell
Re: ASUS BW-16D1X-U - Flashable?
Post by ggrussell » Wed May 15, 2024 5:34 pm
I recently purchased the ASUS BW-16D1X-U with the intention of connecting to my home theater to play UHD discs I have purchased. Found this site.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
I used the SPF to create a firmware dump. Which MK firmware should I use to flash this drive?
Post by d00zah » Wed May 15, 2024 6:36 pm
ggrussell wrote: Wed May 15, 2024 5:34 pm I recently purchased the ASUS BW-16D1X-U with the intention of connecting to my home theater to play UHD discs I have purchased. Found this site.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Asus BW-16D1X-U
Asus BW-16D1HT 3.10MK
ggrussell
Post by ggrussell » Wed May 15, 2024 9:28 pm
Great thanks! Appears to have worked. Can read 4K Disc
But at 100%, SPF flasher popped up an error: 0X82062900
I'll also be using this disc to back up files on MDisc. Any links to reasonably priced 128GB MDisc? LOL
Macguy
Post by Macguy » Fri May 17, 2024 10:14 am
First post after lurking for a long time (and a bit "stoned" with information overload).
So better to ask ...
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 20
Firmware version: ID76
Desktop USB version
Host: MacBook Pro
OS: macOS Monterey 12.7
Would the flasher work with this configuration or is it Windows only?
Just to avoid any misunderstanding: all 4K UHD disks I have are legal and purchased by me.
Thanks for your help.
Post by dcoke22 » Fri May 17, 2024 4:19 pm
Macguy wrote: Fri May 17, 2024 10:14 am Hi,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Desktop USB version
Host: MacBook Pro
The drive platform is Pioneer, not the MT1959 platform that's referenced in the Ultimate UHD Drives Flashing Guide
I do not know if Billycar11 sells a flashing kit for that particular drive or if it can be made to work for 4K UHD ripping.
Post by Billycar11 » Fri May 17, 2024 9:18 pm
I do have a flasher for it but it's windows only so no mac
Macguy
Post by Macguy » Fri May 17, 2024 10:58 pm
Thanks to both of you for a quick reply.
I guess I will need to look around for a Windows pc.
Buying a flashed drive from the US would be too expensive (import duties, customs clearance fees, VAT and shipping costs would amount to anything between 50% and 80% of the US selling price).
Post by d00zah » Fri May 17, 2024 11:31 pm
Macguy wrote: Fri May 17, 2024 10:58 pm Thanks to both of you for a quick reply.
There are buying options in most regions...
Drives for sale, Flashing Services, where to buy...
Asmcom in the EU
MartyMcNuts in Australia/NZ/Singapore
Bluntman in Canada
Macguy
Post by Macguy » Tue May 21, 2024 5:24 pm
Thanks for the info.
The ASUS drive has been returned and I contacted Asmcom to order a "friendly" Pioneer drive.
d00zah wrote: Fri May 17, 2024 11:31 pm There are buying options in most regions...
Asmcom in the EU
Bluntman in Cnanda
markcine
Asus external drive BW-16D1H-U PRO: UHD flash
Post by markcine » Wed Jun 26, 2024 2:14 pm
Hello, I bought an Asus external drive BW-16D1H-U PRO, but it has RS8F00 platform with a Pioneer Drive!
I need it UHD enabled, where do I get the flasher please?
Thanks,
Mark
Re: Asus external drive BW-16D1H-U PRO: UHD flash
Post by Coopervid » Sun Jun 30, 2024 9:14 am
markcine wrote: Wed Jun 26, 2024 2:14 pm Hello, I bought an Asus external drive BW-16D1H-U PRO, but it has RS8F00 platform with a Pioneer Drive!
Thanks,
Mark
Read your PM.
Post by Coopervid » Mon Jul 08, 2024 6:52 pm
Thanks,
Mark
PM deleted since not read within a weel.
FrancisBlack79
Post by FrancisBlack79 » Mon Jul 08, 2024 9:28 pm
Coopervid wrote: Mon Jul 08, 2024 6:52 pm
Thanks,
Mark
Apologies for jumping on this post if it isn't allowed.
I was thinking of purchasing the ASUS BW-16D1H-U Pro as I need an external drive to Rip CD's and Blu-rays and I noticed this post about flashing this drive to read and rip UHD discs, I just wanted to know if that was possible?
Many thanks in advance.
Post by Coopervid » Tue Jul 09, 2024 11:31 am
FrancisBlack79 wrote: Mon Jul 08, 2024 9:28 pm
Thanks,
Mark
This ASUS external drive can contain either a Pioneer drive or a LG type drive. You will only know when it arrives. Pioneers ar the far better drives. LG drives can be flashed with the publicly available flasher.
FrancisBlack79
Post by FrancisBlack79 » Tue Jul 09, 2024 1:05 pm
Thanks for the reply Coopervid :)
Fairly new to the 'UHD friendly drive' scene so still learning!
Basically I'm looking for a drive that I can rip CD's, Blu-Rays and UHD Discs for backup with a high success rate but struggling to find what would be best to buy here in the U.K. The drive itself would be connected to a HP Omen Laptop running Windows 11, any advice would be appreciated or if anyone could point me in the right direction that would be great.
Thanks again
