I recently purchased the ASUS BW-16D1X-U with the intention of connecting to my home theater to play UHD discs I have purchased. Found this site.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
I used the SPF to create a firmware dump. Which MK firmware should I use to flash this drive?
ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
Asus BW-16D1X-Uggrussell wrote: Wed May 15, 2024 5:34 pm I recently purchased the ASUS BW-16D1X-U with the intention of connecting to my home theater to play UHD discs I have purchased. Found this site.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Asus BW-16D1HT 3.10MK
ggrussell
Great thanks! Appears to have worked. Can read 4K Disc
But at 100%, SPF flasher popped up an error: 0X82062900
I'll also be using this disc to back up files on MDisc. Any links to reasonably priced 128GB MDisc? LOL
Macguy
First post after lurking for a long time (and a bit "stoned" with information overload).
So better to ask ...
Drive Information Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 20
LibreDrive Information Status: Possible, not yet enabled
Firmware version: ID76
Desktop USB version
Host: MacBook Pro
OS: macOS Monterey 12.7
Would the flasher work with this configuration or is it Windows only?
Just to avoid any misunderstanding: all 4K UHD disks I have are legal and purchased by me.
Thanks for your help.
Product: BW-16D1X-U
Revision: E113
Serial number:
Desktop USB version
Host: MacBook Pro
The drive platform is Pioneer, not the MT1959 platform that's referenced in the Ultimate UHD Drives Flashing GuideMacguy wrote: Fri May 17, 2024 10:14 am Hi,
Product: BW-16D1X-U
Revision: E113
Serial number:
Desktop USB version
Host: MacBook Pro
I do not know if Billycar11 sells a flashing kit for that particular drive or if it can be made to work for 4K UHD ripping.
I do have a flasher for it but it's windows only so no mac
Macguy
Thanks to both of you for a quick reply.
I guess I will need to look around for a Windows pc.
Buying a flashed drive from the US would be too expensive (import duties, customs clearance fees, VAT and shipping costs would amount to anything between 50% and 80% of the US selling price).
There are buying options in most regions...Macguy wrote: Fri May 17, 2024 10:58 pm Thanks to both of you for a quick reply.
Drives for sale, Flashing Services, where to buy...
Asmcom in the EU
MartyMcNuts in Australia/NZ/Singapore
Bluntman in Canada
Macguy
Thanks for the info.
The ASUS drive has been returned and I contacted Asmcom to order a "friendly" Pioneer drive.
d00zah wrote: Fri May 17, 2024 11:31 pm There are buying options in most regions...
Asmcom in the EU
Bluntman in Cnanda
markcine
Asus external drive BW-16D1H-U PRO: UHD flash
Hello, I bought an Asus external drive BW-16D1H-U PRO, but it has RS8F00 platform with a Pioneer Drive!
I need it UHD enabled, where do I get the flasher please?
Thanks,
Mark
Thanks,
Mark
Re: Asus external drive BW-16D1H-U PRO: UHD flash
Read your PM.markcine wrote: Wed Jun 26, 2024 2:14 pm Hello, I bought an Asus external drive BW-16D1H-U PRO, but it has RS8F00 platform with a Pioneer Drive!
Thanks,
Mark
PM deleted since not read within a weel.markcine wrote: Wed Jun 26, 2024 2:14 pm Hello, I bought an Asus external drive BW-16D1H-U PRO, but it has RS8F00 platform with a Pioneer Drive!
Thanks,
Mark
FrancisBlack79
Apologies for jumping on this post if it isn't allowed.
I was thinking of purchasing the ASUS BW-16D1H-U Pro as I need an external drive to Rip CD's and Blu-rays and I noticed this post about flashing this drive to read and rip UHD discs, I just wanted to know if that was possible?
Many thanks in advance.
This ASUS external drive can contain either a Pioneer drive or a LG type drive. You will only know when it arrives. Pioneers ar the far better drives. LG drives can be flashed with the publicly available flasher.FrancisBlack79 wrote: Mon Jul 08, 2024 9:28 pmApologies for jumping on this post if it isn't allowed.
FrancisBlack79
Thanks for the reply Coopervid
Fairly new to the 'UHD friendly drive' scene so still learning!
Basically I'm looking for a drive that I can rip CD's, Blu-Rays and UHD Discs for backup with a high success rate but struggling to find what would be best to buy here in the U.K. The drive itself would be connected to a HP Omen Laptop running Windows 11, any advice would be appreciated or if anyone could point me in the right direction that would be great.
Thanks again
Thanks again
