Problem after backup
georgesgiralt
Post by georgesgiralt »
Hello Guys,
I've tried to backup a Blu-Ray movie "The Spy gone north" A Korean film.
Backup went smoothly and reported no errors.
But I can't visualise any m2ts file with VLC. All I get is the yellow band moving from right to left and left to right on the progress bar. The total play time stays at zero whatever the file I try to see.
Some help will be appreciated.
Many thanks in advance for your help.
Ezatoka
Re: Problem after backup
Post by Ezatoka »
Did you make a decrypted backup? Because I can still see the AACS directory
georgesgiralt
I don't know. I clicked on the backup icon. (the one with the arrow pointing to the open folder).
I'll try again tomorrow and see what gives.
Edit : i did this on Ubuntu 22.04 LTS using the latest Make MKV version.
georgesgiralt wrote: Mon May 13, 2024 5:47 pm I don't know. I clicked on the backup icon. (the one with the arrow pointing to the open folder).
When you click that button there will be a little screen popup for the output directory. There's also a checkbox to decrypt the files. This must be checked!!
georgesgiralt
Yes, my bad. The check box was not checked. But the message is very misleading in French...
It is running fine now.
Thank you both.
