Drive Angry problems
Blue407
Post by Blue407 »
Hi Guys
Tried to RIP Drive Angry to MKV and it all seemed to work, but when I play the movie it seems to start in the middle???
Does anyone know which sections I need to tick to get the whole movie?
Re: Drive Angry problems
Post by mike admin »
Most likely you've selected the wrong title. Were there many?
Blue407
Post by Blue407 »
mike admin wrote:Most likely you've selected the wrong title. Were there many?
A handful. From memory one at around 17gb, one at 12 and one at 7 all stood out. I obviously picked the biggest but when I play it back looks like mid-point of film.
I usually narrow it down by looking at the audio, but more than 1 had HD soundtrack....
Almost like it more than one title was needed to make the film (Maybe new copyright solution? Splitting up the film into different bits)
setarip_old
Post by setarip_old »
Hi!
That concept is certainly nothing new. If I remember correctly, the first such example was "Ratatouille", back in 2007...
For the "Movie-Only", select 00161.MPLS, with a combined runtime of 1:44:32.033 (19 chapters).
Blue407
Post by Blue407 »
setarip_old wrote:Hi!
In MakeMKV I have the following:-
Title - 11 chapters, 11.7Gb
Title - 7 Chapters, 12.4Gb
Title - 2 chapters, 2.3Gb
Blue407
Post by Blue407 »
In the end I picked 2 seperate titles, something like 5 and 2 which has given me 2 seperate MKV files.
No. 5 is the first part of the movie with No. 2 the last part so I have renamed the title01 and title02 as appropriate.
Any way to join these back together to make one file?
setarip_old
You can use tsMuxer to "Join" (NOT "ADD") the two titles - and save as "Blu-ray"...
robpdotcom
Post by robpdotcom »
You could also use mkvmerge to append them. You'll probably also want to merge the chapter files as well. Let me know, and I can tell you how to do that.
EDIT: Will TSMuxer join the chapters?
Phidens
Post by Phidens »
I have the exact same issue with this Bluray. Using mkvmerge to join the two results in garbage on the screen for approx 1 second where they are joined. Any ideas on how to fix.
