No new beta-key?
CENTRAL
Re: No new beta-key?
Post by CENTRAL » Sun May 12, 2024 5:53 am
It works for me as well. Here is the drill:
Windows 11, active internet connection.
1. In Settings -> Time & Language -> Date & Time
2. Change " Set time automatically" to "Off"
3. Select "Change" in "Set the date and time manually"
4. Jump back one month to April, select "Change"
5. Minimize the Settings window (optional) and start MakeMKV - it will run normally if you have registered with the April key
6. Return to settings and revert the month change back to the current date (if you don't several functions will fail to operate - for example youtube stops loading etc.)
7. Rip your disc, you should be fine.
RustyShamrock
Post by RustyShamrock » Sun May 12, 2024 2:29 pm
New key is now available.
smokeywhitetown
Post by smokeywhitetown » Mon May 13, 2024 5:39 pm
Beta key has been updated, guys.
CENTRAL
Post by CENTRAL » Tue May 14, 2024 6:32 am
RustyShamrock wrote: Sun May 12, 2024 2:29 pm New key is now available.
Thank you Guys!
Great work so far!!!
Cheers.
