LG WH16NS40 1.05 won't downgrade to 1.02
Re: LG WH16NS40 1.05 won't downgrade to 1.02
Did you had to check "Enc" when flashing directly from WH16NS40 1.05 to WH16NS60 1.02-MK? Thank you!
If using the latest version of SDFtool Flasher, the encrypted flag is automatically applied when required. You should see a green tick for both drive platform and encrypted firmware.
Is this the latest version of SDFTool Flasher? SDFtool Flasher (v1.3.5).zip
Yep. It tells you at the top of the post.
Just re-located the post. I had downloaded a few months ago.
Thank you!
Thank you!
