LG WH16NS40 1.05 won't downgrade to 1.02
2-perf
Re: LG WH16NS40 1.05 won't downgrade to 1.02
Post by 2-perf »
Did you had to check "Enc" when flashing directly from WH16NS40 1.05 to WH16NS60 1.02-MK? Thank you!
2-perf wrote: Thu May 09, 2024 7:44 pm Did you had to check "Enc" when flashing directly from WH16NS40 1.05 to WH16NS60 1.02-MK? Thank you!
If using the latest version of SDFtool Flasher, the encrypted flag is automatically applied when required. You should see a green tick for both drive platform and encrypted firmware.
2-perf
Post by 2-perf »
Is this the latest version of SDFTool Flasher? SDFtool Flasher (v1.3.5).zip
2-perf wrote: Fri May 10, 2024 1:47 am Is this the latest version of SDFTool Flasher? SDFtool Flasher (v1.3.5).zip
Yep. It tells you at the top of the post.
2-perf
Post by 2-perf »
Just re-located the post. I had downloaded a few months ago.
Thank you!
