LibreDrive for Pioneer drives
Icebraker wrote: Wed May 08, 2024 12:41 pm Hi all,
I just got a new pioneer BDR-UD03 1.14, ripped a blu-ray straight with makemkv with no problems.
But when I put a UHD Disk into the drive it spits it back out after like 10-15 seconds.
Anybody able to help me or point me in the right direction?
Any help would be greatly appreciated.
Laufwerksinformation
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: AFDL414057WL
Firmware-Datum: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
The BDR-UD03 isn't UHD compatible. The UD04 is.
Phoenix0870
Post by Phoenix0870 »
I have the PIONEER BD-RW BDR-S13U firmware V1.05.
Is there a revised firmware version for this in the meantime?
Phoenix0870 wrote: Fri May 10, 2024 2:42 pm I have the PIONEER BD-RW BDR-S13U firmware V1.05.
Sorry no I recommend you return it.
I still have those with old firmware if you want one see below
Phoenix0870
Is there a flash program that can flash the firmware V1.05 back to V1.02?
(How is LG and ASUS?) Sdftool_flasher.Exe or ASUS_ODD_FW_Changer_(Modified).Exe
Phoenix0870 wrote: Sat May 11, 2024 11:07 am Is there a flash program that can flash the firmware V1.05 back to V1.02?
Sorry no pioneers with new fw can't be downgraded
Quinsster
Post by Quinsster »
I assume this is RIP to make UHD Friendly?
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
Highest AACS version: 72
Firmware version: ID76
Doesn't show as MT1959 in SDFtool as there is a red X next to it , am i missing something for is it a dead end?
Quinsster wrote: Wed May 15, 2024 6:48 pm I assume this is RIP to make UHD Friendly?
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
This is a Pioneer 212 drive, not a LG. Check your PM.
Icebraker
Post by Icebraker »
MartyMcNuts wrote: Wed May 08, 2024 11:08 pm
Produzent: PIONEER
Revision: 1.14
Just got it working with a cfw/Instructions thx to @coopervid
Danke nochmal für die Hilfe
SytealCeladon
Post by SytealCeladon »
Is this one okay to start putting the new firmware on?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CFDL301286UC
Firmware date: 2022-12-27
Highest AACS version: 70
Drive platform: Pioneer RS9331
Firmware version: ID05
PioneerDrive
Post by PioneerDrive »
Hello all,
I would greatly appreciate any feedback on how to get my UHD external Pioneer drive (info listed below from MakeMKV) to be able to rip UHD 4k Blue Ray discs:
OS device name: F:
Revision: 1.02
Serial number: CHDL003642UC
Highest AACS version: 61
Thank You!
P.S. Mike would you by any chance be able to provide instructions?
SytealCeladon wrote: Sun May 19, 2024 9:13 pm Is this one okay to start putting the new firmware on?
OS device name: F:
Revision: 1.02
PioneerDrive wrote: Sun May 19, 2024 9:28 pm Hello all,
Sadly both of you are out of luck there is no way to flash those at all.
I recommend returning them and buy pioneers with old fw from a seller or getting a pioneer 212 and getting it professionally flashed.
SytealCeladon
Billycar11 wrote: Sun May 19, 2024 9:32 pm
Alrighty, thanks much for your swift response!
OS device name: F:
Revision: 1.02
Nope. Cannot be done.
drukhari
Post by drukhari »
I'm not sure if this drive is supported, planned to be supported, or I'm just out of luck. Any advice?
Product: BD-RW BDR-X13
Revision: 1.04
Serial number: CLDL301093UC
Firmware date: 2023-08-01
Highest AACS version: 81
Drive platform: Pioneer RS9400
Firmware version: ID56
Pretty much "planned by Pioneer to not be supported" unless the firmware can be overwritten. Anything with firmware dates after December 2022 is broken deliberately.
