Having trouble ripping Batman The Complete Animated Series 12-disc BD box-set
smokeywhitetown
Post by smokeywhitetown »
For some discs... some-to-several of the episodes will be missing from the rip, some episodes will have blank audio and ripping per disc is taking an extraordinary long time. I unplug my external LG BD drive and restart my Mac computer fully between each rip attempt, just to ensure nothing silly is stopping the process. Help would be appreciated. This is such a shame because I like to keep a digital copy of my discs for personal home use as it is a much better experience than messing around with and possibly scratching discs and wading through annoying menus and wait times.
My external drive:
The box set:
My logs: [might my drive be failing?]
MakeMKV v1.17.1 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WP50NB40 1.01 SIK7AI25N0320d" opened in OS access mode.
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00238.m2ts' at offset '1112064'
File 00055.mpls was added as title #0
Title #00120.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '1179648'
Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
Title #00201.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '2617344'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '4061184'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '9369600'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '9891840'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '10813440'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '11532288'
Title #00071.mpls was skipped
File 00072.mpls was added as title #1
File 00073.mpls was added as title #2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '1044480'
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Title #00082.mpls was skipped
File 00083.mpls was added as title #3
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00350.m2ts' at offset '1701888'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00350.m2ts' at offset '3600384'
Failed to decode audio/video data for title #4 - invalid mux or internal error, title skipped.
Title #00074.mpls was skipped
File 00075.mpls was added as title #4
File 00076.mpls was added as title #5
File 00077.mpls was added as title #6
File 00078.mpls was added as title #7
File 00079.mpls was added as title #8
File 00080.mpls was added as title #9
File 00081.mpls was added as title #10
Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00239.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00316.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00317.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00347.m2ts was added as title #11
File 00350.m2ts was added as title #12
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '8257536'
File 00358.m2ts was added as title #13
File 00362.m2ts was added as title #14
Title #00363.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00364.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00365.m2ts was added as title #15
Title #00366.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00367.m2ts was added as title #16
Encountered 109 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Saving 16 titles into directory /Users/bren/Desktop/Batman TAS
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00348.m2ts' at offset '18806784'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00348.m2ts' at offset '269156352'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '269156352'
Failed to save title 1 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t01.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '61667328'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '118419456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '165150720'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '475066368'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '475066368'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '560658432'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '560658432'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '651491328'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1077669888'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '1077669888'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1106638848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1116143616'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '1116143616'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1116794880'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '1116794880'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1124401152'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1124597760'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1124923392'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1127350272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1127675904'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00349.m2ts' at offset '1130102784'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '1130102784'
Failed to save title 2 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t02.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00359.m2ts' at offset '122222592'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '122222592'
Failed to save title 3 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t03.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00353.m2ts' at offset '2643591168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00353.m2ts' at offset '2647652352'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '2647652352'
Failed to save title 6 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t06.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '19003392'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '19003392'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '19722240'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '123924480'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '141029376'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '141029376'
Failed to save title 11 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t11.mkv
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '3600384'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00350.m2ts' at offset '3667968'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '3667968'
Failed to save title 12 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t12.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '52426752'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '52426752'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '91551744'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '91877376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '111605760'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00358.m2ts' at offset '130086912'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '130086912'
Failed to save title 13 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t13.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00362.m2ts' at offset '7077888'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00362.m2ts' at offset '10616832'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '10616832'
Failed to save title 14 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t14.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00365.m2ts' at offset '13369344'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00365.m2ts' at offset '18935808'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '18935808'
Failed to save title 15 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t15.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '3403776'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '3403776'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '3667968'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '3993600'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '7206912'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '7471104'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '8060928'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00367.m2ts' at offset '8386560'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '8386560'
Failed to save title 16 to file /Users/bren/Desktop/Batman TAS/BATMAN™- The Complete Animated Series Disc 1_t16.mkv
Encountered 333 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
6 titles saved, 10 failed
narrativemonk
Re: Having trouble ripping Batman The Complete Animated Series 12-disc BD box-set
Post by narrativemonk »
I'm having a similar issue using a Pioneer BDR-S13U-X 5.25 SATA via my Mac.
@smokeywhitetown did you ever find a solution?
Anyone else have any idea what the issue might be?
narrativemonk wrote:
Wed May 08, 2024 3:03 pm
Copy & paste the MakeMKV log of a failed rip into a post here. Can't really tell what might be happening without some log data.
Phoenix0870
Post by Phoenix0870 »
I search for my Pioneer BD-RW BDR-S13U Firmware V1.05.
Who can help me?
My Windows system is Windows 7 Ultimate 64Bit.
OS-Gerätename: K:
Aktuelles Profil: CD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S13U
Revision: 1.05
Serienummer: xxxxxx
Firmware-Datum: 2023-08-01
Firmware version: ID43
Disk-Informationen
Label: MC2
Zeitstempel: 2001-07-17 15:22:07
Datenkapazität: 0.56 Gb
Hope someone can help me?!
