Hi!
First, this app is awesome. Thanks for all your support to the community. Next, I may have overlooked this option if it exists, but if it doesn't, it might be a useful feature to include some sorta "default" options in terms of what people normally enable. Specifically, I would find it useful to have a way to turn the selection of subtitles OFF by default, as some discs come with a MILLION language choices and it's very time consuming to individually disable each subtitle track before I convert to an MKV.
With the latest builds of HandBrake, that app actually chokes on MKVs if there are too many subtitle tracks. While this sounds like a HandBrake problem, it seems like a quick fix and useful feature could be to help "manage it" on the front end within MakeMKV.
Thanks again!
Feature Request: Instantly Disable Subtitles
allthingschris
Re: Feature Request: Instantly Disable Subtitles
This functionality is coming. Meanwhile you can right-click on any subtitle and select "Unselect all".
paisan
Ditto on the request. For me, I need the switch via the command line. I don't see any way to do subtitle manipulation via the CLI
Great tool!
Great tool!
Smithcraft
I wish I knew about that an hour ago!mike admin wrote:This functionality is coming. Meanwhile you can right-click on any subtitle and select "Unselect all".
SC
Smithcraft
Still hoping for this as an option...
SC
SC
Coming soon...
