infectedrain
Post
by infectedrain » Mon Apr 29, 2024 10:12 pm
Model Name : PIONEER BD-RW BDR-UD03D
Firmware Rev : 1.00
Extra Info : 14/05/14 PIONEER
Hi
Is there a chance to convert it to UHD friendly drive?
Post
by Billycar11 » Tue Apr 30, 2024 2:50 am
infectedrain wrote: Mon Apr 29, 2024 10:12 pm
Firmware Rev : 1.00
Hi
yeah email me i have an automated flasher for that
Azathanai
Post
by Azathanai » Wed May 01, 2024 12:51 am
I'm a bit confused by this guide. Does the section "drives that Currently work are:" mean that the drives in this list are capable of ripping 4k straight from the box?
Post
by MartyMcNuts » Wed May 01, 2024 1:50 am
Azathanai wrote: Wed May 01, 2024 12:51 am
No. The Pioneer models work if they are on older firmware (pre Dec 2022). Essentially all of them now require flashing (no publicly available flasher for Pioneer drives) as they have newer firmware.
Azathanai
Post
by Azathanai » Wed May 01, 2024 4:57 am
MartyMcNuts wrote: Wed May 01, 2024 1:50 am
Can every drive be flashed by the guide given under " How To Flash Videos and commands:"? If not, which ones can?
Post
by MartyMcNuts » Wed May 01, 2024 11:47 pm
Azathanai wrote: Wed May 01, 2024 4:57 am
LG/ASUS drives can using the flashing methods mentioned in the guide.
Tom899
Post
by Tom899 » Sat May 04, 2024 7:48 pm
I purchased a Pioneer BDR-213/2213 SATA 5.25 SATA with BDR-S13UBK Firmware from Billycar11 in March of this year. I also purchased an LG Electronics WH16NS40 drive from Amazon and flashed it myself. I had an ASUS drive prior for a few years that finally crapped out.
Anyway, I've been using both the LG and Pioneer drives to rip discs, both in Vantec cases, mostly 4K, some Blu-Ray and a few DVD. The LG is a little faster and noisier than the Pioneer.
BUT, I tell you what, The Pioneer is the Top Dog! There have been a number of instances where the LG has practically stalled out and I had to abort, it slowed down to a crawl and said 7 hours left (you know what I mean). I go right to the Pioneer and faithfully get a good rip with no problems!
If you are looking for one drive to get, get a Pioneer from Billycar11 and be done with it. I'm highly satisfied with the Pioneer and Billycar11 customer service.
Tom
Prophacesi
Post
by Prophacesi » Sat May 04, 2024 8:38 pm
I had flashed my BP50NB40 to BP50NB40-NB50-1.03MK with the SDFtool Flasher, but still couldn't read UHD discs. I found your guide and realized I needed to flash from where I was up to BP60NB10 1.02MK. I did that in the flasher also, everything works now!
Thank you!
taipei72
Post
by taipei72 » Mon May 06, 2024 1:30 pm
First time here... Been going through this post.. Lot of valuable info...
I just purchased a Archgon.. Is it possible to flash to get it to work... I am little new at this.. Here us the info on my drive
OS device name: /dev/rdisk4
Current profile: CD-ROM
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO2N95D5557
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: 010802_1617
Timestamp: 2001-08-03 16:38:12
Data capacity: 0.63 Gb
BTW, I did do the extract HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 and on Mac terminal, I ran all the way till step 7 and it said it is 100% complete, but when I open the drive it ti shows above with 1.02
Am I missing something post the flash???
What did I do wrong..
Thank you in advance...
saskiuhia
Post
by saskiuhia » Mon May 06, 2024 3:38 pm
Hello everone.
I just bought an LG BU40N drive and was trying to flash it.
MakeMKV doesn't show platform and LibreDrive info:
Revision: BN14
Serial number: ***
Firmware date: 2121-06-21 13:33
Highest AACS version: 78
SPFtool Flasher don't allow me to do anything because it think that it isn't MT1959 platform.
I just don't understand what's wrong with it.
Post
by Billycar11 » Tue May 07, 2024 2:34 am
saskiuhia wrote: Mon May 06, 2024 3:38 pm
Hello everone.
Revision: BN14
Serial number: ***
yes the buffalo cases do that you will have to use cli or get an auto flasher.
MrDystopian
Post
by MrDystopian » Fri May 10, 2024 12:07 am
EDIT: Sometimes I drive myself nuts. I flashed the drive some time ago and did not realize I used the "MK" bin. That was the issue. Once I re-flashed using the non "MK" bin, everything was back to normal. Ignore the stuff below...lol
___________________
First post and I registered here for this. Long time read, first time poster. Appreciate all the hard work that has gone into this guide. I used it myself several years ago when I got my drive.
So I recently discovered an issue that was not there before and I am curious if anyone else is seeing it. I have an LG BD-RE WH16NS60. Flashed to 1.02. It works flawlessly in MakeMKV, and it used to work in DVD Fab as well. Now DVD Fab tells me I have a UHD friendly drive, but need to downgrade the FW. Again, it is worth noting that it rips just fine in MakeMKV. Anyone else having issues recently with DVD Fab?
OS device name: H:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: (hidden by me)
Highest AACS version: 76
MrDystopian on Fri May 10, 2024 1:54 am, edited 1 time in total.
Post
by MartyMcNuts » Fri May 10, 2024 1:46 am
MrDystopian wrote: Fri May 10, 2024 12:07 am
OS device name: H:
Revision: 1.02
I'm pretty certain that NS60 1.02-MK has never worked with DVDFab as it doesn't like MK firmware. NS60 1.00 firmware does as it is an original firmware (not an MK one). If you want to use this drive with DVDFab, flash it to WH16NS60 1.00.
digitaltrance
Post
by digitaltrance » Thu May 16, 2024 2:58 pm
I feel like a new post needs to be made for 2024 with clearer instructions? Maybe it's just information overload for me and being led to different threads and posts that lead to another set of confusions.
Anyway, I have a LG - BP60NB10
What all do I need? From the very first post, it seems I need:
1. The firmware (I downloaded "The all you need firmware pack" - file 'HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin')
2. The flasher - which one is it? GUI SDF tool or LG flasher + DE firmware ?
thx for clearing my head.
